Manifold bolts question
Old Aug 26, 2017 | 05:42 PM
Orion1976's Avatar
Orion1976
Do the manifold to head bolts need to be sealed? Will oil seap out if not? Dont want to ruin this pretty new Edelbrock intake...
Old Aug 26, 2017 | 05:54 PM
jakeharp's Avatar
jakeharp
fe?
The manifold bolts do not need to be sealed... Your intake gasket is keeping everything sealed, use a quality intake gasket, most folks also lay a bead of RTV around the water passages, where you may have pitting on your cast iron heads.....and nothing replaces a good clean surface, heads should be shinny clean, revealing any and all pitting.....
Old Aug 26, 2017 | 05:56 PM
Orion1976's Avatar
Orion1976
Thank Jake,
Ive only worked on 302s, this is the first foray into the FE world.
Old Aug 27, 2017 | 09:05 AM
fasthauler's Avatar
fasthauler
I can't recall any manifold bolt that enters an oil passage so oil seepage shouldn't be a problem. I learned a long time ago from bitter experience to use a good anti-sieze on the threads of the bolts. This can save a lot of grief later.
Old Aug 27, 2017 | 09:22 AM
Glens67's Avatar
Glens67
Also install the distributor and follow the torque chart. Watch the distributor for clearance issues, keep turning the distributor, adjust clearance as you tighten the intake.
qman
Jul 15, 2015 09:44 AM
wildhog8
Sep 10, 2007 10:27 PM
mike demos
Jun 17, 2005 06:02 PM
TxBrokenarrow
May 25, 2005 09:42 PM
Mikeman
Aerostar
Mar 26, 2002 12:18 PM
