Original '64 without driver side mirror option
Old Aug 26, 2017 | 01:51 PM
rtcapo's Avatar
rtcapo
I just brought home a '64 Ford F100 home without driver side mirror option installed.
Question, is the truck more valuable without as originally ordered?
thanks
rtc
Old Aug 27, 2017 | 08:54 AM
g4g2g7's Avatar
g4g2g7
thanks
rtc
​​​​​​​even trucks without mirrors should still have the hole in the door (for the mirror arm) and a rubber plug in the hole. So if you wanted to add the factory round style mirrors, you could just pop the plug out and bolt them on...wouldn't hurt the value because they could always be removed and the plug put back in. Now if asking about adding larger western style mirrors that need holes for screws, then ultimately I think that's subjective and everyone will have their own opinion. My opinion is that unless it's an extremely well documented low mileage all original truck, then, no, you won't hurt the value by adding mirrors that install by drilling holes.
Old Aug 27, 2017 | 09:31 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Besides the chrome mirrors that fit into the door slots, there were two other types with recatngular mirror heads: Telescoping and non telescoping.
See post #22 in mirror sticky.
Old Aug 27, 2017 | 10:07 AM
anthony myrick's Avatar
anthony myrick
I have a 63 that was ordered without mirrors and only had one sun visor
installing a factory style mirror will not affect any value but will make your neck happier
Old Aug 27, 2017 | 10:56 AM
NumberDummy
ALL outside mirrors were optional excepting 1965/66 F100/250 Camper Specials, the Western Jr. mirrors were part of the package.
Standard Cabs came with one sunvisor as standard equipment, Custom Cabs and Rangers came with two.
Old Aug 27, 2017 | 03:44 PM
rtcapo's Avatar
rtcapo
[QUOTE=g4g2g7;17424554]​​​​​​​even trucks without mirrors should still have the hole in the door (for the mirror arm) and a rubber plug in the hole.
On this '64, there is a plug hole for for the radio antennae, not for the mirror, I haven't seen any stamp marks from the factory.
I am looking for a happier neck though...probably hang one out there in the future.
Thanks for the input.
rtc
Old Aug 28, 2017 | 09:29 AM
NumberDummy
Ford never used a plug for a radio antenna. The radio was an option, so there would be no hole in the right cowl panel without one.
All 1961/66 trucks have slots in the doors for the optional outside mirrors. If no mirrors were installed, rectangular rubber plugs filled the holes.
Old Aug 28, 2017 | 12:59 PM
rtcapo's Avatar
rtcapo
Cool. Thanks for the heads up. i'll have to go out and study up on her. I've been using most of my time making room in the garage for her. I haven't had too much hands on time.
thanks again
rtc
Old Aug 28, 2017 | 01:28 PM
arctic y block's Avatar
arctic y block
Can we see a pic of this gem?
Old Aug 28, 2017 | 03:58 PM
Skervey's Avatar
Skervey
Put these on my grandpas 64
https://www.summitracing.com/parts/u...AaAlq3EALw_wcB
They kinda suck but its better then nothing and they look right at home on the truck.
alvald83
Aug 21, 2010 08:44 AM
Big Skier
Mar 23, 2008 03:03 PM
AtypclEngr
Mar 27, 2005 11:22 AM
transam525
Feb 7, 2003 09:03 PM
GolferSA
Oct 7, 2002 11:41 AM
