Transmission swap
Old Aug 26, 2017 | 01:54 AM
Burtj28's Avatar
Burtj28
Transmission swap
I currently have a 1995 f250 with the 7.5L 460 engine in it. Awesome truck!! The only problem is it has an automatic transmission in it!! Just curious about how difficult it would be to convert it to a manual transmission and what would need to be added or replaced. Need all the information and tips I can get!!
Old Aug 26, 2017 | 06:57 AM
quaddriver's Avatar
quaddriver
well you need the transmission withe the proper bell, prolly from another 460. likely need the correct length driveshafts.
you need a PCM that no longer speaks transmission and you need the wiring to put the starter circuit off the clutch rather than park and the crusie disconnect has to add clutch. you need the pedal assemblies and master cyl, slave cyl etc.
basically, a donor truck.
Tuttle69
Apr 7, 2016 10:48 PM
Dan16
Apr 21, 2015 03:30 AM
Old Blue 2
Dec 16, 2008 10:49 PM
Doc1
Engine Swaps
Aug 7, 2005 10:16 PM
Greywolf
Nov 4, 2001 09:12 AM
