Excursion 6.0 Starting Issue
Old Aug 24, 2017 | 03:59 PM
captcruz's Avatar
captcruz
Hello. Today went to start up the 6.0 Excursion, engine cracked over very good as it should but would not start. I checked battery terminals and wires attached all tight. I waited about 15 minutes before calling ford and it fired right up, checked several times during the day with no issues. Anybody ever had this happen to them or heard of this. Why it would it not fire up and then 15 minutes later did.
Thank you.
Old Aug 24, 2017 | 06:54 PM
Stewart_H's Avatar
Stewart_H
Moved over to the 6.0L PSD forum.
Stewart
Old Aug 24, 2017 | 07:35 PM
Don Naslund's Avatar
Don Naslund
Would be wild guesses without some meter readings. It could be wiring harness or high pressure oil leaking down during the night. Yes, it has happened to a lot. You can do a search here or on youtube Just check for 6.0 hard starting. My best wild guess would be dummy plug seals. Possibly the reason that it started after cranking for a while, you just refilled the high pressure system.
FLO98
May 11, 2016 10:50 PM
Pocketlint
Mar 23, 2015 12:02 PM
bf2389
Nov 23, 2012 10:19 PM
Ford67
Oct 22, 2010 04:59 PM
John P.
Aug 7, 2005 08:45 AM
