So CEL light came on and truck has been shuting off on me at lower RPMs
Also noticed when i shift the shifter into (Drive) it engages much faster than usual
so I changed my CPS and getting the same results.
Any thoughts would be great. Ty
1280 = Signal voltage was less than .039 volts for more than 0.2 seconds
0475 = Exhaust pressure control valve malfunction
On the 1280 it's probably a bad ICP or connection. If unplugged and inside the connector there is oil then it's starting to leak. Could be other things but this is a starting point. Read actual pressure with a scanner if possible.
On the 0475 if the EBPV is removed or unplugged that code is generated.
On the 0605 if the truck is chipped this code can be generated.
I would think so. It needs ICP to maintain an idle so if it's getting a bad reading and ICP drops too low then the injectors won't fire and it shuts off.
If there's oil in the plug, replace the sensor. Might fix your issue, might not, but it's a clear sign it needs replaced regardless.
