Waste gate solenoid?
Old Aug 23, 2017 | 06:17 PM
DeeDubz's Avatar
DeeDubz
After I shut my truck off I can hear a small pump like sound on the drivers side of my truck... I was told its most likely the waste gate solenoid, I'd like to confirm as well as how to fix this. Someone mentioned replacing the wiring harness to the waste gate.
Heres the Video. Please help me out
Truck details
2011 F250 6.7 80K
Old Aug 23, 2017 | 07:52 PM
69cj's Avatar
69cj
It's probably the def pump draining the lines that you hear. You don't have a problem in my opinion. They all do it that I've been around.
Just listened to yours. Is quit a bit different in sound than mine and seems to last a little longer.
Old Aug 23, 2017 | 08:04 PM
DeeDubz's Avatar
DeeDubz
Why would it start doing this after 75 K? that at least when my 6.7 started. Is there a problem with my def sys?
Old Aug 23, 2017 | 08:18 PM
slorider's Avatar
slorider
Sounds like the waste gate to me. To confirm, next time you shut off your truck and the buzzing starts press on the brake. If it instantly goes away it's the waste gate. My '11 started doing it around 20k miles, which was about 70k miles ago. Ford used to replace them early on, although determined nothing was malfunctioning and stopped doing it.
Old Aug 23, 2017 | 08:19 PM
DeeDubz's Avatar
DeeDubz
BINGO SLORIDER! THANK YOU, so theres no issue?
Old Aug 24, 2017 | 04:07 AM
EO2SeaBee's Avatar
EO2SeaBee
Waste gate. Mine does it too. You can replace the vacuum harness to it if it's too annoying for you.
The DEF pump running in reverse to evacuate the line from the injector back to the tank sounded like a dull whistling noise from under the driver's side on mine, and nothing under the hood. (Mine no longer does that either though since it had weight loss surgery.)
Old Aug 24, 2017 | 11:25 AM
golfmedik's Avatar
golfmedik
Oh, so Bear had gastric bypass coupled with a bowel resection huh?
Old Aug 24, 2017 | 11:30 AM
EO2SeaBee's Avatar
EO2SeaBee
Sort of like removing the appendix so that it doesn't create issues later on. I wasn't having any issues, and didn't desire to in the future.
Old Aug 24, 2017 | 12:48 PM
DeeDubz's Avatar
DeeDubz
how much did it cost you? Is it a PIA to replace?
Old Aug 24, 2017 | 01:20 PM
EO2SeaBee's Avatar
EO2SeaBee
Monty and I were goofing off and may have led to some confusion. I have not done anything to remedy my wastegate solenoid. I live with the racket when I shut down. The noise I previously spoke of that I no longer hear at shutoff, is the DEF pump running backward to evacuate the lines, as my truck no longer requires DEF.
Old Aug 24, 2017 | 03:46 PM
DeeDubz's Avatar
DeeDubz
Thanks for the clarification
Old Aug 24, 2017 | 04:51 PM
darren32's Avatar
darren32
Like Doug said, no issue, my 2011 has been doing it for 7 years.
hschiro
6.7L Power Stroke Diesel
Jan 1, 2014 01:07 AM
hschiro
Jul 23, 2013 08:58 PM
nabor j1
Feb 14, 2012 07:22 AM
Brian429
2004 - 2008 F150
Aug 13, 2007 07:42 AM
RichC
19
Jun 3, 2007 09:25 AM
