truck will not start
Old Aug 22, 2017 | 06:52 PM
Alex1221's Avatar
Alex1221
2012 F350 battery light is on and check engine light is on, still have power to everything but truck will not turn over, just tells me to pull off the road...
Old Aug 22, 2017 | 08:45 PM
Just Strokin's Avatar
Just Strokin
Has there been any maintenance to the truck recently? Visits to the dealer?
How old are the batteries? Have either or both been replaced?
You might try disconnecting the batteries for a few minutes and see if the problem still exist when you connect them back.
Old Aug 22, 2017 | 11:32 PM
1911fan's Avatar
1911fan
Did you check the voltage
Old Aug 22, 2017 | 11:35 PM
1911fan's Avatar
1911fan
Just a few guesses fuse, relay, starter, neutral start switch
Old Aug 23, 2017 | 04:38 AM
EO2SeaBee's Avatar
EO2SeaBee
If it is telling you to pull off the road, the thing that used to trip that fairly routinely was a faulty EGT sensor. A reflash corrected that so that we will no longer be shut down by it. Do you know if you ever got that reflash done? I don't remember right off hand if it was a recall or if it was a TSB. If you have a scanner or access to one, see if any codes pop up for EGT.
Old Aug 23, 2017 | 01:11 PM
golfmedik's Avatar
golfmedik
This is what I was going to say as well. Sounds like an emissions failure of some sort of a fuel delivery issue.
Old Aug 23, 2017 | 01:28 PM
EO2SeaBee's Avatar
EO2SeaBee
I thought about fuel too Monty, but he indicates it's not even turning over. Low fuel pressure should still allow it to turn over, right?
Old Aug 23, 2017 | 01:29 PM
golfmedik's Avatar
golfmedik
Yep, guess I missed that part. Wonder if the starter cables are tight and the bolts are all still tight as well.
Old Aug 24, 2017 | 03:17 PM
Alex1221's Avatar
Alex1221
Sadly it looks like its the exhaust system is taking a dump, which is causing the trucks computer to see it as over heating, thus shutting it down dead to keep it from damaging the turbo... kinda odd that was giving me a battery light and a check engine light but after pulling 16 codes all linked to the exhaust system... what else could it be? also was never re-flashed made it 159959 miles no problems. Was told by local exhaust shop it would cost me 5k to delete the crappy system out of the truck or spend 10 to 15k to rebuild to oem.
Old Aug 24, 2017 | 03:39 PM
Just Strokin
you may have some EGT's bad....they are like $50 each........EGT #4 is the one that will shut you down if you have not had the ECU flashed.
Old Aug 24, 2017 | 03:52 PM
Alex1221's Avatar
Alex1221
its a company truck, my boss and exhaust shop guy are friends so ill let them work it out. I work for a small company and my boss is a really good guy so I like to fix things on my own if I can, but I really appreciate the help, will let ya'll know all the fun bits if I can.
Old Aug 24, 2017 | 07:36 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Off the wall..alternator going south. Had something similar on our 6.0
Proudtruckowner
63
Nov 15, 2016 09:15 AM
Littlejon
1997 - 2003 F150
Mar 21, 2016 12:19 AM
sola forda
44
Mar 6, 2013 05:03 PM
tdives
1997 - 2003 F150
Jan 25, 2012 04:29 PM
5.0 Junkie
15
Mar 25, 2010 06:21 AM
