Sponsored by: Auxito
Rough idle when in drive
Old Aug 23, 2017 | 12:11 PM
Jinglesmell1334's Avatar
Jinglesmell1334
Hi all,
I bought this truck used and when it's in drive the engine idles rough and seems about to stall when the ac is on at a stop sign or red light.. I've tried it w/o the ac on and it seems a little better but not as smooth. Idle in park is fine.
Do you know when I should start looking?
Spark-plugs? spark plugs wires, disturber cap, fuel filter ect...
Please i'm not that mechanical but I can get most jobs done. So I don't have any master mechanic tools... if it's something easy i can do...
Old Aug 23, 2017 | 03:08 PM
Sam I Am's Avatar
Sam I Am
Originally Posted by Jinglesmell1334
I bought this truck used and ...
We can't see which truck you are pointing at.
Also some history of the the maintenance on this vehicle would help narrow it down. And code scan it. Or looking at live data is a really great diagnostic tool for computer controlled engines.
Old Aug 23, 2017 | 06:54 PM
Jinglesmell1334
Oh sorry forgot to add it
1997 Ford F-150 XL model it has over 194,000 miles on it. As for maintenance I have no idea as it was used. I have changed the oil and transmission oil but other then that nothing else that I know of. That's why I was maybe thinking its the spark plugs as the seem a little black when I removed one to see what conditions they were in
Old Aug 27, 2017 | 06:30 PM
Jinglesmell1334
Alright I've replaced the spark plugs, air filter and spark plug wire. It still has a rough idle. Do you think it's the pvc valve?
Old Aug 27, 2017 | 10:10 PM
Bluegrass 7's Avatar
Bluegrass 7
What is the hot Idle RPM in Neutral or Park?
Should be close to 650/700 +/-.
If not the IAC is not functioning.
When A/C is turned on, an Idle correction is made to keep the Idle in the 700 rpm range.
If that does not happen the A/C loads the motor down.
The hotter it is out, the more it loads the motor.
Good luck.
Old Sep 5, 2017 | 07:01 PM
Jinglesmell1334
Update:
I've replaced the pcv valve and cleaned the iac valve. Now it seem to be miss firing around speeds for 45 and above. What else can I be looking for? New iac value?? Do you think I can take it to advance auto and they can see if any codes come up. The check engine light doesn't come up or anything. I'm drawing at straws here guess what the fix is.
Old Sep 5, 2017 | 08:48 PM
Bluegrass 7
Taking it to an auto store won't likely result in any solution to the misfire without code............unless they know how to access mode 6, test 53.
At that data location will be found the misfire monitors for each cylinder.
One or more may show misfire counts out of limits.
If so that cylinder will need the coil replaced.
Good luck.
Old Sep 7, 2017 | 01:48 PM
Jinglesmell1334
You mean replacing the Ignition Coil?
FiveOJester
2009 - 2014 F150
Feb 28, 2017 06:20 PM
berry1234
Apr 5, 2012 01:55 PM
jkarne
2004 - 2008 F150
Sep 3, 2010 08:35 AM
1BadF150
1997 - 2003 F150
17
Jan 12, 2005 10:35 PM
1BadF150
Modular V8 (4.6L, 5.4L)
Jan 9, 2005 10:35 AM
