Aerostar Ford Aerostar
86 Aerostar clutch problem
Old Aug 23, 2017 | 12:04 AM
rosett's Avatar
rosett
I have an '86 Aerostar with the 2.3l engine and 5-speed trans. Two years ago, I had a clutch job done, and everyting was fine for about 3000 miles. Then, I started hearing and feeling grinding when the van is stopped, and the clutch pedal fully depressed. If I lift the pedal just a bit, the grinding stops. This problem comes and goes at random, and sometimes it's fine for months. I've taken it back to the shop that did the work, but of course it does do it there.
It doesn't seem to affect the driveability of the van, and it shifts fine, but it sounds bad. Any ideas?
Old Aug 23, 2017 | 12:29 AM
xlt4wd90's Avatar
xlt4wd90
Sounds like the throwout (release) bearing may be failing. Did they change it when they replaced the clutch?
Old Aug 23, 2017 | 12:30 AM
rosett's Avatar
rosett
He said he did.
Old Aug 23, 2017 | 05:31 PM
xlt4wd90's Avatar
xlt4wd90
Well, it sounds like the replacement is starting to go, and probably needs to be replaced soon. I guess 2 years is out of the warranty period.
Jared Ryan
Mar 20, 2017 02:15 AM
peanut butter
32
Jul 4, 2015 12:12 AM
puck1263
May 24, 2006 01:08 PM
Lukes66
May 22, 2003 05:24 PM
alantbird
Nov 17, 2001 09:10 PM
