What year 4.9
Old Aug 22, 2017 | 03:25 PM
ciamcoop's Avatar
ciamcoop
What year 4.9
I just picked up a 96 f150 4.9 5 speed. I guess the head gasket went and then the guy just parked it. It's been sitting for almost a year so now the motor is stuck. I'm just looking for an engine to put in it to keep it cheap. What year range will have the same efi setup on it? Or at least let me bolt up my efi stuff?
Old Aug 22, 2017 | 03:37 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
'96 is something of a one-off, as it's the first and last year for OBD2 on the F150. The long-block is pretty much interchangeable with earlier years (back to '87) but you'll need to move a bunch of stuff over from your '96.
Are you sure the engine is done? It takes a lot to kill a 4.9.
Old Aug 22, 2017 | 04:29 PM
ciamcoop's Avatar
ciamcoop
I haven't really looked at it. It wouldn't crank so I put a ratchet on the balancer and it won't turn. Could just be rings rusted to the cylinders, don't know yet. It has 240k miles on it so if it's junk that's the way it goes I guess.
Old Aug 23, 2017 | 10:30 AM
DPDISXR4Ti's Avatar
DPDISXR4Ti
I would put a big breaker bar on it and force it over, then spin it over a bunch by hand. At this point what do you have to lose, right?
Old Aug 23, 2017 | 12:55 PM
Rusty96's Avatar
Rusty96
put some penetrating oil in the cylinders and let it sit. Then after a day or two try to turn it over.
Mixing 50/50 ATF and acetone makes a good penetrating oil, seems to get thru the rust better than pb blaster imho.
Old Aug 23, 2017 | 01:17 PM
ciamcoop's Avatar
ciamcoop
Yep, I did that. Hoping for the best.
Old Aug 23, 2017 | 01:26 PM
88n94's Avatar
88n94
If the head gasket went, and there is any chance of repairing the engine, the head would have to come off anyway. I would remove the head and see what things look like. If it doesn't look too bad, you could take a block of wood and a sledge hammer and beat somewhat on top of the pistons to try and loosen the engine up.
Old Aug 23, 2017 | 01:37 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
^^^ All good advise. FWIW, when I got my replacement 4.9 engine for $75, it was in "as-is", unknown condition. It had as much oil in the sump as water (not coolant). I hand spun it around a few times, it started right up and has been running fine for thousands of miles.
Muppy1840
Jun 8, 2015 08:20 PM
Mark Strauss
Jan 28, 2014 08:56 AM
revlimiter776
Jun 14, 2009 11:54 AM
dtoolman38
Sep 20, 2006 08:46 PM
MercMan
Dec 4, 2002 01:41 PM
