Anyone re-geared?
Old Sep 6, 2017 | 05:50 PM
  #31
2009kr's Avatar
2009kr
Originally Posted by LiquidSteam
Where's the lifetime mpg? Lol
14.1, over the past 9500 miles. I posted it when it was 14.3 before my last big mountain tow.
That includes about 8% of the miles towing at 26K GCW and lower mileage the first few tank while the engine was breaking in and running winter fuel.
Towing, I typically get 8.5 - 10 (8.5 at 70+, 10 at 55-60), empty, I typically get 15.5.
Old Sep 12, 2017 | 07:08 PM
  #32
tw450's Avatar
tw450
Originally Posted by tw450
Ok talked to west coast diffs and The gear shop. Both really nice and helpful (reasonable prices too). But I am being told there are currently no options to run 4.10?? They are saying 3.73 and 4.30 only. Anyone have any insight? Seems like 4.10 would be the sweet spot for the 6.7 and 37's..
Just wondering if anyone had anything to add here? I guess no 4.10's at the moment unless someone knows otherwise? Not sure about the 3.73 vs 4.3 - I feel like 3.73 is too tall and 4.30 would be too low with 37's.
Old Sep 12, 2017 | 07:17 PM
  #33
kylant's Avatar
kylant
isn't there a model that offers 4.10 from ford?
Old Sep 12, 2017 | 07:18 PM
  #34
2009kr's Avatar
2009kr
The 4.30 feels great with my factory 31.9" tires on my F450. Surely a 4.30 isn't too much for 37's!
Old Sep 12, 2017 | 07:24 PM
  #35
C_Smitty's Avatar
C_Smitty
I was on the Ford parts website today looking up gears and the do have 4.10 gears for the front but not for the rear. Only 3.73 and 4.30 for the rear.
I too wanted 4.10, but will probably go with 4.30. Ford Parts Unlimited have both front and rear 4.30 gears for $542 shipped...
  #36
tw450's Avatar
tw450
I was told no - so I guess no current models are offered with the 4.10's? With the f250 axles anyway..
Good to hear!! It's my daily and I drive mostly city but it does go on long road trips unloaded (so 80mph) - I was worried about the rpm's being too high.
Old Sep 13, 2017 | 07:05 AM
  #37
kylant's Avatar
kylant
4.10 is an option on a F350 dually. so the gears should be available for at least the bigger axle. I believe the F250 uses the same Sterling axle the Super Duty has had for years, so 4.10 should be available
Old Sep 13, 2017 | 10:12 AM
  #38
C_Smitty's Avatar
C_Smitty
You need to be very careful about buying gears from previous year Super Dutys. On the 2017 250s they have a 35 spline axel shaft where previous year models with the same Dana 60 front and Sterling 10.5 rear, they used 31 an 37. If you want to play it safe I'd stick to the oem 3.73 or 4.30 35 spline gears.
Old Sep 13, 2017 | 10:22 AM
  #39
nbayless36's Avatar
nbayless36
just a quick figure with an rpm calculator you're only looking @ about 110 rpms higher @ 70mph withe the 4.3 over 4.1
Old Sep 13, 2017 | 11:07 AM
  #40
C_Smitty's Avatar
C_Smitty
What size tires did you input and what did you enter for your transmission ratio? I believe the ratio on the automatic is 0.67:1 in 6th gear...
Old Sep 13, 2017 | 11:40 AM
  #41
nbayless36's Avatar
nbayless36
Apple's to Apple's it doesn't matter the the transmission or tire size as long as you compare 37s to 37s or 31s to 31s the final gear ratio is the only thing that changes
Old Sep 13, 2017 | 08:16 PM
  #42
tw450's Avatar
tw450
Thanks for the comments guys! I guess 4.30 might not be a bad alternative.. Still debating but want to get rid of these 3.31's asap!
Old Oct 6, 2017 | 07:29 PM
  #43
Roly Poly's Avatar
Roly Poly
tw450,
Did you swap your gears yet? Was wondering if the 3.31 carrier is the same carrier used for the 3.55, 3.73 and 4.30's.
Roly
dewalters8886
Feb 17, 2017 10:29 AM
gorkah
Sep 15, 2015 10:47 AM
SuperWoman77
Jul 16, 2013 08:14 PM
77_F150_4x4
Nov 22, 2007 11:08 AM
Pocket
Oct 20, 2006 11:59 PM
