1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
what year rear axle lug threads the same?
Old 08-21-2017, 12:48 PM
MONAVIERONJON's Avatar
MONAVIERONJON
MONAVIERONJON is offline
I have an early 99 f250 srw and am in the process of installing some wheel spacers for some 2007 f250 srw wheels. The front axle is a 2002 and the 8x 170 spacers fit as well the acorn nuts for them. Now the rear is a different story, the spacers fit the bolt pattern although the thread pitch does not match. so im going to have to buy some acorn nuts for the spacers. Im wondering if this is a 97 rear axle or somethiing newer? what year are the threads different on a 8x 170 bolt pattern? thanks!1
Old 08-22-2017, 09:02 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
99 through 2003ish ford used metric course thread studs, 2003 on ford went to metric fine thread studs
Old 08-23-2017, 04:22 AM
Y2KW57's Avatar
Y2KW57
Y2KW57 is offline
Received 3,429 Likes on 1,799 Posts
1999 - 2002 = M14 x 2.0
2003 - beyond = M14 x 1.5
M14 - denotes stud diameter in millimeters
2.0 and 1.5 - denote the distance between thread crowns in millimeters, where 2.0 (coarse) is greater distance peak to peak than 1.5 (fine)
Unlike English/American/SAE thread pitch designations, in metric fasteners, the larger thread pitch number denotes more distance in millimeters between thread crowns. In this case, it is not "threads per millimeter". It is rather "millimeters per thread." Or more precisely, millimeters between thread crowns.
Old 08-24-2017, 01:12 PM
MONAVIERONJON
thanks for all the info, im thinking since this is an e99 it might be a 98 model axel which would make this a 97 axle. Both tags are on the rear cover , is there a code that might reveal anything helpful?
markshr151
01-14-2018 07:05 PM
RTM
03-29-2004 09:38 AM
bob-63-292
Garage & Workshop
16
01-13-2004 09:32 PM
Quick Reply: what year rear axle lug threads the same?
