Need help decoding vin.
Old Aug 20, 2017 | 03:57 PM
Mr.FordMan's Avatar
Mr.FordMan
C60BU853372
Model C600
Body691
Trans M
Axle74
Max gvw 20000
Old Aug 21, 2017 | 10:42 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Mr.FordMan
C60BU853372 // Model: C600 / Body: 691 / Trans: M / Axle: 74 / Max GVW lbs: 20000
C60 = C600 Tilt Cab (gas).
B = 300 1V I-6.
U = Louisville KY Assembly Plant.
853372 = 1966.
C600 Tilt Cab (gas); 20,000 lbs. GVWR
691: 6 = Black all Vinyl / 91 = 91A Standard Tilt Cab.
M = Clark model 250V 5 Speed Direct or Spicer/Dana model 6452-A 5 Speed Direct.
74 = Timken model H140 Single Speed Rear Axle / 6.80-1 / 17,000 lbs. Axle Capacity.
20,000 lbs. Gross Vehicle Weight Rating.
Old Aug 21, 2017 | 10:50 AM
Mr.FordMan's Avatar
Mr.FordMan
B = 300 1V I-6.
853372 = 1966.
I knew you'd come through. Now I just have to figure out what motor and transmission are in it because the guy who has it has not swapped motors and its a v8 of some sort.
Old Aug 21, 2017 | 10:57 AM
Mr.FordMan's Avatar
Mr.FordMan
Is there anywhere else that a vin could be on that truck? I'm talking to the guy who owns it and the previous owner wrecked the truck and replaced the cab so the tag on the door isn't right. He is pretty sure it is a 60 or 61.
Old Aug 21, 2017 | 10:59 AM
Mr.FordMan's Avatar
Mr.FordMan
B = 300 1V I-6.
853372 = 1966.
Old Aug 21, 2017 | 12:19 PM
NumberDummy
1948 and newer trucks are registered by their specific VIN's.
There is a hidden VIN stamped on a frame rail, but where it's located on a C series, I haven't a clue.
Suggest asking this and further questions in the LARGE TRUCK forum. Most members of this forum have 1961/66 F100/250/350 pickups.
1957/86 C series cabs are similar, but 1958/60's have dual headlamps, while 1957 & 1961/86's have single headlamps.
Old Aug 21, 2017 | 07:29 PM
Mr.FordMan's Avatar
Mr.FordMan
Alright. He is going to get the title and see if it says the same vin or not.
4BDiesel
Large Truck
Feb 24, 2019 06:18 PM
tinman52
Large Truck
Dec 18, 2018 10:44 PM
Trucker man
Large Truck
Dec 29, 2016 04:16 PM
Snowmanii
Large Truck
Oct 23, 2016 11:17 AM
Oldtrucklover80
Large Truck
Oct 8, 2016 11:55 AM
