Sponsored by: Real Truck
What is this connection for?
Old Aug 19, 2017 | 08:49 PM
luv2offroad2's Avatar
luv2offroad2
I have a 2000 F250 V10. I noticed a hose dangling from the front wheel the other day. I reconnected the very old hose but noticed there isn't one on the other side (it's missing). The hose goes from the driver's side wheel to the passenger side wheel. Can some one tell me what these connections on the wheel are for?
Old Aug 19, 2017 | 08:57 PM
m-chan68's Avatar
m-chan68
Those hoses are your vacuum supply for your Pulse Vacuum Hubs. They supply vacuum to engage/disengage the hubs to the axles when 4x4 is selected/deselected with the hub lock in the AUTO position.
Old Aug 20, 2017 | 09:09 AM
luv2offroad2
Thank you! I guess I'll replace those hoses and clean out the connections then.
Old Aug 20, 2017 | 06:44 PM
thomabb's Avatar
thomabb
I assume your ESOF doesn't work?
Old Aug 20, 2017 | 07:14 PM
luv2offroad2
Honestly, I don't use the 4-wheel drive all that much. Mostly in winter. I did use it once this summer and it seemed to engage just fine.
Old Aug 21, 2017 | 07:40 AM
thomabb's Avatar
thomabb
Did you have to lock you hubs manually? Without those vacuum lines, the auto hub function will not work.
Old Aug 21, 2017 | 09:50 AM
andym's Avatar
andym
Your 4x4 still works fine but you have to get out to lock the hubs in. The dash switch will put the transfer case in 4H but without those lines the hubs won't lock. Before you spend any time or money on this, put a vacuum pump on each hub and see if they hold vacuum. If they don't, then just replacing the lines won't work as it needs to have an airtight seal to engage the hubs.
Old Aug 21, 2017 | 11:10 AM
luv2offroad2
I watched a youtube video on this yesterday. I guess I really didn't have 4x4 when I switched the switch. I'm not getting the defroster blowing with air on to indicate the auto hubs are not working, but whatever. I've already ordered the hoses for a whopping $1.27. So no loss there if replacing them doesn't work. If they are still not working after replacing the hoses then I'll find someone with a vacuum to test the system.
ufvj217
Sep 22, 2013 07:40 PM
vronp
Sep 23, 2012 08:00 PM
lcmains1
Jan 18, 2012 03:47 PM
gafftbk
Dec 1, 2009 09:42 PM
DUALLYNOTED
Apr 22, 2007 01:23 PM
