Sponsored by: Real Truck
Bed Repair
Old Aug 15, 2017 | 12:57 PM
Mike1's Avatar
Mike1
Bed Repair
So I thought I'd post some pictures of what I did over the weekend. The bed on my 03 was so rusted, if I'd had try to carry anything it probably would have fallen through. I knew the bed had issues, but there was an 8' sheet of plywood in the bed and I never really lifted it up to see how bad the bed really was until I was staring at the truck a few weeks ago and I asked my son, "are my eyes playing tricks or is the bed of the truck falling in the front?"
I am farther along than these pic show, but I stopped work on it for a few days to recoup. It was a hard nasty hot job that got plenty of cuts and scrapes, and I'll never do it again. I know the beds are really expensive to buy anywhere from $1500 - $3000 but if I had spent the money I'd have been done in a day instead of 3 days and it's still not bolted down.
That's not me in the truck, it's one of my son's friends helping me out.
The fender humps had to be cut out also we inserted the blue box into the open shell.
Old Aug 15, 2017 | 01:00 PM
andym's Avatar
andym
That's awful what salt does to trucks. Is the rest of the underside in as bad of shape?
Old Aug 15, 2017 | 01:56 PM
Mike1's Avatar
Mike1
Sheet metal wise, the bottoms of the doors inside and outside are toast, needs new doors, rocker panels and cab corners are toast. believe it or not the floors and rest of the truck is solid.
Old Aug 15, 2017 | 01:59 PM
andym's Avatar
andym
I think I would have sold it or junked it if it were me.
Old Aug 16, 2017 | 07:15 AM
Mike1's Avatar
Mike1
At 135K the truck still has a lot of life left in it. Why would I want to sell it or junk it just because it needs a little work? Granted, I probably picked the wrong path to take on this repair, but I got it finished with help from my son and his friends, and the best part about it is the whole repair only cost me about $300 so far That's buying a crashed up bed, hardware, welding materials cutting disks and food to feed the troops. The next big expense is to buy some sort of spray or roll on liner for the inside of the bed.
My motto used to be "It's just metal, cut it and weld it." but it's getting a little harder as I get older...LOL
Old Aug 16, 2017 | 07:48 AM
Mike1's Avatar
Mike1
This still has to finish being welded in but it it's been tacked and stitched, will have a little grinding on some of the welds and then coated with liner.
Old Aug 19, 2017 | 10:44 PM
jp267's Avatar
jp267
Interesting thanks. I have a hole on the side of the bed and the crossmembers are pretty much gone. So I'll be going through the same exercise dreadfully.
Funny thing is the rest of the bed, the frame itself, suspension components and cab are relatively rust free or just have surface rust.
Wonder if the plastic bedliner contributed to the rot.
Old Aug 20, 2017 | 09:05 AM
dx3's Avatar
dx3
Mine doesn't have holes but it is pretty beat up. I was considering this as it is relatively inexpensive and seems to get some pretty good reviews. I know most people prefer the Por 15 route however.
https://www.amazon.com/Linerxtreeme-spray-Bedliner-Kit-1-5/dp/B008IGOVHQ/ref=pd_sim_236_1?_encoding=UTF8&pd_rd_i=B008IGOVHQ&pd_rd_r=JS18DSR473QF18BKZPQJ&pd_rd_w=ICtrf&pd_rd_wg=2mOhz&psc=1&refRID=JS18DSR473QF18BKZPQJ https://www.amazon.com/Linerxtreeme-spray-Bedliner-Kit-1-5/dp/B008IGOVHQ/ref=pd_sim_236_1?_encoding=UTF8&pd_rd_i=B008IGOVHQ&pd_rd_r=JS18DSR473QF18BKZPQJ&pd_rd_w=ICtrf&pd_rd_wg=2mOhz&psc=1&refRID=JS18DSR473QF18BKZPQJ
Old Aug 20, 2017 | 08:11 PM
senix's Avatar
senix
I would be spraying fluid film all over the underside of the truck a couple of times a year to help with the rust and salt prevention.
Old Aug 21, 2017 | 11:13 AM
Mike1's Avatar
Mike1
Sorry to hear you're in the same boat. This was a major PIA, 4 people total 2.5 days and I still need to put a few welds on it to make me happy, then put a lining on it.
Yes the plastic liner did contribute to the rusting out., the dirt and water get trapped in there and can't get out, Midwest salted roads don't help and if you're not getting a power washer or spray hose under it to get all the salt off, these beds and cabs rust quick.
Old Aug 21, 2017 | 11:18 AM
Mike1's Avatar
Mike1
https://www.amazon.com/Linerxtreeme-...R473QF18BKZPQJ
I can't vouch for one or another spray(roll) in liner, however, all I can say is Prep is key to any application, power wash, scruff up the adhering surface, put down a good primer, make sure it's 100% cured, wash out again, make sure it's complletely dry then apply the coating. I've hear some guys have lined their truck and the 1st time they load something the liner scratches and chips off.
hail destroyer
Aug 23, 2016 09:34 AM
ericford1984
Oct 23, 2011 07:37 PM
michael.biasi
Apr 23, 2011 12:38 AM
FordF350Baby
Paint & Bodywork
Jul 15, 2008 12:34 PM
TJDREAMS
Oct 30, 2004 12:53 AM
