Locking fuel cap
Old May 7, 2018 | 09:08 AM
  #46
HRTKD's Avatar
HRTKD
Originally Posted by NVFord03
Do you know if the Start 10510D will be the correct one for my 2003 F350 PS 7.3?
Thanks
This PDF from Stant should tell you which cap works for your model year truck: Stant Catalog. Go to page 98.
Old May 7, 2018 | 02:41 PM
  #47
alaska #1's Avatar
alaska #1
Originally Posted by alaska #1
So let me ask you a question since the instructions weren't very robust. When you popped the tabs the next step says to unhook the spring and use a punch to knock out the pin holding the fuel door on to the assembly. After you got the tabs loose did you pull the whole thing out fuel door hinge and all or did you have to take the pin out from behind the body panel? Thanks.
Disregard...I figured it out. Lots of questions asked so let me give my run-down... Take off both caps. Next, from behind the tank door panel you have to get all 4 of those push tabs loose. Next take off the rubber sheet that surrounds the two filler necks. As you're looking at that sheet from the fuel door side it has two of those crinkle snap tabs on the left and just two spade fingers on the right. Comes off pretty easy. Now that everything is loose/removed carefully remove the entire unit door and all from the vehicle by working it out to the right and kind of toward you.. Once out, the spring on the door hinge came off easily and the pin they speak of comes out from the top down not the bottom up like most would think. Drill the 4 holes like the instructions say, assemble with the provided hardware and then snap it in place with the 4 tabs that we originally took out from behind. (Just line it up and push it pack into place until all 4 snap back in.) Install the rubber sheet back around the filler spouts by inserting the 2 spade fingers then snap in the two catches on the other side. Put the caps back on and done.
Old Jun 13, 2018 | 12:45 PM
  #48
Fordism101's Avatar
Fordism101
I chose billet!
Old Jun 13, 2018 | 12:51 PM
  #49
HRTKD's Avatar
HRTKD
Originally Posted by Fordism101
I chose billet!
Where did you get that from?
Old Jun 13, 2018 | 01:48 PM
  #50
Fordism101's Avatar
Fordism101
Amazon
Old Jul 22, 2018 | 03:20 PM
  #51
cadent49's Avatar
cadent49
what about a locking def cap? what's the part number?
Old Jan 21, 2020 | 09:10 PM
  #52
william_04_x's Avatar
william_04_x
Bump...
How about securing the caps/doors on a 2019 F350 w/6.7?
Old Jan 21, 2020 | 09:53 PM
  #53
SARDiverDan's Avatar
SARDiverDan
Edit - post removed
Old Jan 21, 2020 | 09:57 PM
  #54
mattymax's Avatar
mattymax
Pictures when you’re done please
Old Jan 22, 2020 | 08:00 AM
  #55
william_04_x
It'll be nice when someone offers a solution for both fuel, and DEF caps.
Old Jan 22, 2020 | 08:03 AM
  #56
TCNashville's Avatar
TCNashville
I'm seriously considering this one for my '17 F-250 gasser. A bit pricey though.
Amazon Amazon
Old Jan 22, 2020 | 10:41 AM
  #57
Sasha4's Avatar
Sasha4
I just found this. Wasnt even on any Google searches. Found their locking DEF for Dodge Rams and then went to their site. Nothing yet for DEF but this is for the F-250-550
Not cheap but billet- $50
From their site:
This Loc-Sure is a non-vented, screw-in, locking billet cap for the diesel filler neck on the 2008-2017 Ford diesel trucks (F-250, F-350, F-450, F-550).
The Loc-Sure offers protection from fuel thieves and from malicious people who would contaminate your fuel. The Loc-Sure utilizes the parent company's Secure Screw system which has been tested and approved by military and other secure facilities as a low-level human secure system.
The Loc-Sure features a 2.5" diameter top face with scallops and knurling for good gripping. The U-Cup seal contacts both the inside and the outside diameter of the fuel filler rim to ensure a proper seal.
Each Loc-Sure purchase comes with the Loc-Sure cap and a molded Secure Key with complimentary stainless steel key ring. Additional keys can be purchased using the information from our Keys page.
BEM Auto's Loc-Sure body is fully machined from aluminum bars at the BEM Auto factory and is finished in a generic green anodized surface, etched to identify the assembled unit as a diesel only cap. The Secure Screw is manufactured from 18-8 stainless steel to provide good corrosion resistance.
https://www.bem-auto.com/product/loc...iesel-trucks/1
Old Jan 22, 2020 | 11:41 AM
  #58
HRTKD's Avatar
HRTKD
That's a nice looking fuel cap. But you can get a locking Stant cap for a lot less.
Old Jan 22, 2020 | 11:51 AM
  #59
Sasha4's Avatar
Sasha4
True but it’s plastic and everyone has the same key. This is a lot more secure and designed to Mil-Spec. To each their own. Just another option and still cheaper than the door option.
Old Jan 22, 2020 | 03:04 PM
  #60
speakerfritz's Avatar
speakerfritz
dont waste your money on locking caps.....you can open them by threading a wood screw on a slight angle.
get a locking door instead.
