Key got wet
Old Aug 19, 2017 | 05:22 PM
Truckpilot1329's Avatar
Truckpilot1329
Key got wet
2012 F150 key got a little wet, and now it seems to be in the same condition as my late iPhone, that went through a washing cycle.
Any ideas on bringing my key back to life?
Thanks
Old Aug 19, 2017 | 05:35 PM
Truckpilot1329
I'll answer my own question.
Good news. It started working again after sitting around drying out, with the battery out, and taken apart, for
a couple hours.
Old Aug 19, 2017 | 07:56 PM
Kingofwylietx's Avatar
Kingofwylietx
That's good info and I'm glad it worked out for you
Old Aug 19, 2017 | 11:35 PM
GlueGuy's Avatar
GlueGuy
What I would mention is that you can (1) take it apart (and remove battery), and (2) put it in a bowl filled with dry rice. Let it set in the rice for a couple hours, and clean and re-assemble. The rice will act as a desiccant, and will dry it out pretty well.
Old Aug 20, 2017 | 11:40 AM
Jafo56's Avatar
Jafo56
Unbelievable!!!...... ok a lot of truck guys are hunters....so your in the middle of the woods in east bumble scum hunting you take a fall into water and get hurt...the only way out for medical attention is your truck!..... does it run or no?..... the joys of electronics!..... the only reason I bring this up is we had a similar thing with are ATV's on a hunting trip involving water and a quad with electronics on it
Old Aug 20, 2017 | 11:51 AM
leikos's Avatar
leikos
That's what the keypad is for. Leave the key in the truck if there's a chance you might go swimming.
Old Aug 20, 2017 | 02:04 PM
Kingofwylietx
We used to go ATV'ing and would put our key & wallet in a small waterproof container.
Old Aug 21, 2017 | 05:09 PM
CR172's Avatar
CR172
Another good reason not go above the XLT "luxury". One still has an actual key so if the fob doesn't work..... who cares.
Old Jul 22, 2022 | 09:37 PM
ctweibel's Avatar
ctweibel
3rd Gear
Went swimming in the ocean with my Ford Focus Key in my suit
I tucked my Ford Focus key in my swiming suit and went into the ocean. When I tried to start my car, no key detected. I had another key and was able to start my car.
I have ADHD and when I made it home, I had both keys in my hand but locked the car with the "bad" key. (What?!?) The "good" key was still in the car, locked. I searched the internet and found your the Ford Truck Forum and your thread and decided to open the "bad" key and let it "dry" as you said. It took a while but I was finally able to unlock the car and get the "good" key. The "bad" or soaked key still could not start the car. I will post if it does. Salt water is more corrosive than fresh so I will have to wait so see if it is functional or will have to be replaced. Thank you for your post. God Bless.
Old Jul 22, 2022 | 10:49 PM
JKBrad's Avatar
JKBrad
Welcome to FTE ctweibel,
Spray it out with WD40 then electrical parts cleaner. Replace the battery. If it still has problems, take the circuit board part out and put it in the oven at 250F for about 20 min. That will remove any moisture. I doubt any solder paths were cracked just from getting wet but if you still have an issue after that back at 425F for 15 min to reflow the solder.
I dried a wet flip phone out years ago by taking the battery out and leaving on the dashboard for a few hours on a hot summer day. Worked great afterwards.
Old Jul 23, 2022 | 03:18 PM
ctweibel's Avatar
ctweibel
3rd Gear
Wet key - No key detected
Left the key "open" with battery out all night. It's working very well now.
Old Jul 23, 2022 | 03:21 PM
ctweibel's Avatar
ctweibel
3rd Gear
Left the key "open" with battery out all night. It's working very well now. Thanks for the tip.
Old Jul 24, 2022 | 11:57 AM
GlueGuy's Avatar
GlueGuy
The other thing that's known to work is to get a small jar and fill it with dry, uncooked rice. Leave your fob (or whatever) in there overnight, and the rice will act as a desiccant and dry the thing out.
Jftruck150
2009 - 2014 F150
Oct 6, 2019 11:21 PM
Jftruck150
Electrical Systems/Wiring
Nov 27, 2014 08:36 PM
EXv10
Mar 4, 2014 09:10 AM
cmalley12
6.4L Power Stroke Diesel
Dec 3, 2012 08:29 PM
goatdriver
2004 - 2008 F150
Sep 18, 2008 02:54 PM
