Dyna 65 Twin I Beam Front Axle Question
Old 08-17-2017, 07:07 PM
1993 ford's Avatar
1993 ford
1993 ford is offline
Hello I have a 1993 f-250 with a 7.3 nonturbo it has the dana 50 twin I beam axle on the front. I have both sides on the front apart right down to the axle stub because I'm doing ball joints. I am replacing the seals that slide on the axle stub and the passenger side axle stub had a collar that the end of the seal slides on and the right side doesn't have one. Is it suppose to have one. If so can I just slide the seal on it and put everything back together and drive on. I will include a picture of the passenger side one so you know what I'm talking about. Thanks
Old 08-17-2017, 09:07 PM
tecgod13's Avatar
tecgod13
tecgod13 is offline
No such thing as a Dana 60 twin I-beam.
You have a Dana 50 if its got the twin beams.
Old 08-18-2017, 02:09 AM
hairyboxnoogle's Avatar
hairyboxnoogle
hairyboxnoogle is offline
Dana 50 twin traction beam. Either way, i would look up the replacement parts and have a gander at them. A sleeve or collar couldve been installed if the seal was replaced before in order for the seal to not wear in the groove the old seal created. Dunno on an axle seal, but common on main seals.
ethand320
04-24-2014 06:14 PM
mikefender
04-21-2007 09:16 PM
wanabe2
1999 to 2016 Super Duty
01-02-2007 07:58 AM
scottty
01-29-2006 03:01 PM
Quick Reply: Dyna 65 Twin I Beam Front Axle Question
