Hi I Was Wondering If Anyone Knows The Procedure For Changing The Front Axle Seal On An 991/2 F250 With The Dana 50 Front Axle. The Front Passanger Side Is Leaking And I Was Told That You Need A Special Tool To Strech The Case To Remove The Seal. Thank You For Your Help
You don't need to stretch the case if your not changing any bearings or gears. The oil seal is sometimes tough to install with the limited space. The inner wheel seals will have to be replaced. You will destroy them getting them out. Replaceing them will be the toughest part.
