Sponsored by: Real Truck
Rear differential ID
Old Aug 26, 2017 | 05:04 PM
82_F100_300Six's Avatar
82_F100_300Six
Are 2WD rear ends different than 4WD? I've been looking at rear sway bars and they have different part numbers for two and four wheel drive.
Old Aug 27, 2017 | 03:13 PM
ligito's Avatar
ligito
Bump .
Old Aug 27, 2017 | 03:15 PM
ligito's Avatar
ligito
How much, if clutch packs need to be replaced?
How much work to replace the clutch packs?
Old Aug 30, 2017 | 11:52 AM
Mike Mike's Avatar
Mike Mike
My mechanic had the problem quickly checked by a rear diff Man and told him because both the wheels were spinning forward I had an open diff while I still having three verified LSD verification documents.Can both wheels spin forward in a LSD if both the clutch packs are worn out? Thank you
Originally Posted by Mike189677
The 10/04 is the month and year build date of your truck so it was built in October of 2004, which would make it an 05. For example my truck was built in 08/03 but is a 2004 model year. So now all your info makes since and corresponds to the tag on your axle
It looks like you have a 3.73 limited slip rear end from your axle tag in the picture. If The code on your door sticker under axle is C1 that would confirm 3.73 limited slip. You would need 75w140 synthetic oil most of it already has the limited slip additive in it, except for the motorcraft is the only one I've found that doesn't have it but I haven't looked too hard either. If you just use the oil off the shelf with the additive in it just be alert for any chatter from the rear end afterwards if it happens you can add some more friction modifier to it. I would just get some rtv and make your own gasket I've never bought a new gasket anytime I've ever had to reseal a diff. I'm sure they are readly avaible though at the parts store if that's the way you want to go.
Old Jan 13, 2019 | 09:40 AM
Shorty Thompson's Avatar
Shorty Thompson
Read through most of these. And I have to give thanks to the gent for correcting me and sending me here . I posted my issues in the wrong area , which his reply accompanied with a link brought me straight here. I can feel my transfer case kick in, but that's it. 4x4 does not work. So I tried turning the hub lockers. They won't move off free at all. Can I use something to make/force them to move . Or is this a bad idea ?
Old Jan 13, 2019 | 10:55 AM
Mike189677's Avatar
Mike189677
you can try to turn them with a pair of channellocks but I wouldn’t try too hard if you know what I mean, other than that taking them out and rebuilding them or replacing them is going to be your best bet most of us go with warn premiums. There are some write ups here for cleaning them and bringing them back to life.
Old Jan 13, 2019 | 02:33 PM
Shorty Thompson
And did exactly that ! I got it to turn . I'll be trying it in a few to see if it works
burnhedge
May 20, 2019 07:47 PM
jakeharp
Apr 1, 2017 10:40 PM
ssmandavid
May 9, 2016 04:27 PM
ladewigm
Jan 30, 2003 01:35 AM
