Intermittent wiper switch question.
Old Aug 16, 2017 | 07:04 PM
KsHighboy's Avatar
KsHighboy
I have an intermittent wiper switch from a 79 f350. Just wondering what is involved in putting a 79 switch into my 67 for intermittent wipers. Anybody done this?
Old Aug 16, 2017 | 07:10 PM
JEFFFAFA's Avatar
JEFFFAFA
Fits right in. Except the shaft has to be cut a little shorter. You need more than just the switch to install intermittent wipers though. Go here:
How to Install a '78-'79 Factory Wiper Delay Setup
A photo-tutorial on adding a very simple and convenient option using factory parts
Old Aug 17, 2017 | 09:57 AM
TeachNlive4ever's Avatar
TeachNlive4ever
Plug and play.
You don't HAVE to cut the shaft, but it is a little longer. It you do decide to cut it, use a hacksaw and don't heat up the shaft. It will melt the contacts to operate the washer motor.
Old Aug 17, 2017 | 03:29 PM
lee's Avatar
lee
Best Mod I have done to my truck (I live in the Great North-Wet).
Old Sep 18, 2017 | 08:04 PM
KsHighboy's Avatar
KsHighboy
Well, I got my intermittent wiper switch installed. Still need to mount the box to the steering column support. With my old switch you really couldn't tell much difference between the two speeds of the wipers. With this switch it's the same. The intermittent part works and the wipers work in both continuous speeds but there's just no hi speed. I've noticed the wiper motor has yellow writing on it like it was replaced at one time but just not sure why I don't see more of a difference in the two speeds. Sometimes it speeds up on high but mostly you can't tell high from low. Any ideas?
Old Sep 19, 2017 | 06:41 PM
JEFFFAFA's Avatar
JEFFFAFA
I would guess a dry windshield and a weak wiper motor or just a plain old worn out motor.
Old Sep 20, 2017 | 07:08 PM
KsHighboy's Avatar
KsHighboy
It has set under an oak tree this past week and had a lot of sap o the window and it actually stopped the wipers. I sprayed the window with soapy water and it picked a lot ! Think the motor is tired.
Old Sep 21, 2017 | 03:39 PM
CrossPlainCrazy's Avatar
CrossPlainCrazy
Marky48170
Aug 24, 2025 04:25 AM
captain1997
Dec 17, 2011 05:16 PM
supercabfreak
18
Aug 21, 2010 09:16 PM
JFR3
Sep 23, 2003 07:07 PM
Phobia16V
Mar 20, 2003 07:44 PM
