Wiper Switch For 1977
Old 09-12-2003 | 11:48 AM
JFR3's Avatar
JFR3
Is there an "upgrade" from the regular 2-speed wiper switch that I currently have that would give me intermittent wipers? Hard to get used to the constant wipers being on.
Old 09-12-2003 | 12:01 PM
lantzn's Avatar
lantzn
I just bought the upgrade from a fellow on eBay for my 79 f150. I remember one fellow saying that the 78-79 intermittent switch can easily be adapted to the earlier models. I can't remember exactly what he said needed to be done but I think it had to do with shortening the switches rod so it didn't stick out from the dash. I'll see if I can find his auction.
Old 09-12-2003 | 12:18 PM
ecarter50's Avatar
ecarter50
To add intermittent wipers you will need the switch and control box. It all plugs in with no modifications on 73-79.
Old 09-12-2003 | 12:24 PM
lantzn's Avatar
lantzn
Must have been the 72 and earlier that needed the mod.
Old 09-12-2003 | 12:39 PM
JFR3's Avatar
JFR3
Thanks for the info. I'll see what I can find this weekend.
Old 09-12-2003 | 01:48 PM
79_250RangerLariat's Avatar
79_250RangerLariat
You can find them on ebay quite often, or check the local "used parts grounds". I belive any delay setup from a 73-86 will work with no modification. The 87-up need a wire swapped I think....
Old 09-13-2003 | 03:45 PM
76supercab2's Avatar
76supercab2
Go to the upper right hand corner of this page. Click on the Tech Articles button. There is an article there with pictures about installing intermittent switch in a 73 to 79 truck.
Old 09-13-2003 | 10:40 PM
Mil1ion's Avatar
Mil1ion
These are listed in our classifieds.
Old 09-22-2003 | 04:21 PM
JLb300's Avatar
JLb300
Will this switch and control box also work on a 1971?
Old 09-22-2003 | 07:09 PM
Mil1ion's Avatar
Mil1ion
With a Modification they will.
Old 09-23-2003 | 04:02 AM
JLb300's Avatar
JLb300
What modification would I need for the 1971 intermittent wiper installation? Thanks
Old 09-23-2003 | 07:07 PM
mk's Avatar
mk
If you'll compoare the timer box plug to the dash harness plug, you'll see one wire out of line. This is for the washer function. Match up the wires and it'll work fine. I've found that interval switches from 73-86 will work in all years from 67 up as well.
mike
