Loose column shifter, caused no start.
This is a FYI thread.
I parked my 96 F Superduty with a 460/E40D/4.30 in the street, and left her there for a few weeks. This is a new to me truck. The column shifter was extremely loose, and sometimes selecting a gear was difficult. This truck has 240000 miles of plowing under its belt, and has probably been shifted between D and R a billion times. I went out to start it, and it wouldn't even turn the starter. I whipped out my old screw
driver and jumped the start solenoid and she took off.
Went to the parts store and grabbed a push button momentary switch to run to the start solenoid because I was just too lazy to diagnose the real problem. I pulled into my driveway, (which is sloped) and threw it in park. Shut it down and let off the brake.
Guess what? The truck started rolling down my driveway before I could open the door. Bingo, there my problem. I started to trace out the shift linkages and cable, and immediately found that the linkage coming straight out of the steering column had 2 very loose bolts. Tightened those baby's up, and bam, I've got a tight column shifter and the truck easily goes into every gear, even park, and now she starts.
So, if your old truck is high mileage, take a peek under your steering column and tighten this stuff up, it may tighten up your shifter and keep you from losing your truck down a slope and possibly killing yourself or others. Will post pictures of this when I get home and take some.
Stay safe!
Stay safe!
sparky
12-05-1999 05:38 PM
