*** The Official Superduty Morning Coffee Thread ***
#3406
Yeah, I have the B+W gooseneck hitch underneath the rubber mat already installed. And the Andersen fifth wheel hitch will mount to any standard rail system. I like the idea of the Curt being able to be easily removed from the bed but I like the price of the standard rails. It’s basically a decision between buy once cry once or be a cheap *******...
#3407
#3409
. Byron, It’s not cheap as in junk but it’s the cheaper option of the options available. The bolt down rails that most use in their trucks are about $180 but they’re also permanent in the truck bed, which I’m not really a fan. The Curt adapter, on the other hand, is just basically removable rails that connects via the B+W Gooseneck hitch already installed but it also costs $500. I’ll probably just bite the bullet and buy the Curt but I need to bitch a bit more about the cost. I’m also considering fabricating my own set of removable rails.
#3411
. With a fifth wheel camper using a gooseneck attachment puts extra leverage on the front of the camper and can cause additional stress to the frame of the camper. I have a F350 Dually so I’m not concerned as much about the truck payload...
#3412
. Yeah, same principle the rails connect to the gooseneck mount on truck then attach your fifth wheel to hitch rails. I’ll take a look at what draw Tire has for an adapter. Thanks Can you post up a picture?. With a fifth wheel camper using a gooseneck attachment puts extra leverage on the front of the camper and can cause additional stress to the frame of the camper. I have a F350 Dually so I’m not concerned as much about the truck payload...
#3413
I see what you have now, the pictures I posted, the first one with the red attachment actually is the fifth wheel hitch by Andersen. The red adapter gets attached to the camper and then you have more of a gooseneck attachment which provides more turning radius and a smoother transition without the clunking of a fifth wheel plate like you have in your pictures. I just need to figure out how I’m going to attach the Andersen hitch to the truck. Andersen actually make one that just drops down into the gooseneck ball but for what I paid for what I have I can buy the rails and still come out ahead. The Curt X5 basically drops into the gooseneck on the truck, you secure it with the pin underneath and then just put that Anderson hitch on the rails and you’re ready to go. B+W makes a fifth wheel companion hitch that has the same principle of yours. However, it weighs 206 pounds and even used they’re running about $900.
#3414
#3416
Since purchasing my Hydra from Gear Head years ago, I have never even tried the PHP tunes that came with it. When life slows down a bit, I might have to give PHP a shot.
I know you had some issues with the 1023 tunes, but I swapped to them just before installing the SXE and was very impressed at how well the truck ran. Even with a modified stock turbo, it held it's own in 5th gear where ith GH I would have to downshift to 4th.
#3419
I remember reading in the 5th wheel/gooseneck section about that particular 5th wheel hitch John posted, or it could of even been here in this section I dont remember, where the hitch bend after a hard braking scenario or something to that degree. I see if I can dig it up.
I can tell you I much prefer the steel rail mount design over the aluminum goose neck design. The guy that bought our Montana trailer had the goose neck version and I just didn't care for it.
On a side note, Adam, when are you coming out with more videos? The first one had us cracking up.
#3420
