junkyard speed control?
Old Aug 16, 2017 | 04:50 AM
shameless's Avatar
shameless
would it be worth getting a speed control system from a junkyard truck? if so, how hard is it to swap from the jy to my non speed control truck?
Old Aug 16, 2017 | 12:11 PM
Canus's Avatar
Canus
f t was me I would use a new aftermarket unit. What you find in a junkyard may or more likely may not be functional and would be a bear to install.
Old Aug 16, 2017 | 08:52 PM
garypettengill's Avatar
garypettengill
Not that difficult. I did it with my '77 years ago. You need the steering wheel, the computer from up under the dash and the wiring harness to it, under the hood you need to get the vacuum servo and the plastic piece off the throttle linkage at the carb. I eventually changed my '77 to a '78/'79 tilt steering column and upgraded to an '80+ steering wheel which has the resume button on it. Used the computer from the later model which plugged right in to the existing harness. Oh, take pictures of the vacuum tubing inder the hood to help in hooking yours up. My truck was a '77 F-150 Custom cab, no frills truck from the factory. It is now equiped with factory air conditioning, cruise control, tilt steering, and interval wipers. The beautify of these old trucks is the factory used a common wiring harness in them so the plugs you need are already there.
Old Aug 17, 2017 | 11:40 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Factory installed Speed Control introduced in 1975 F100/350 & Econoline.
The factory parts used 1975/77 are mostly different than the factory Speed Control parts used on 1978/79 F100/350, Bronco & Econoline.
Factory installed: The Speed Control switches are located in the horn pad. 1975/77 Speed Control horn pad and steering wheel different than 1978/79.
Dealer installed Speed Control: The switch clips onto the turn signal handle.
Note 1978/79: There is no horn relay unless the F100/350/Bronco/Econoline has factory installed Speed Control.
The horn relay attaches to the Speed Control Amplifier, located on the inside of the firewall adjacent to the fuse box.
Old Aug 17, 2017 | 01:20 PM
jack orchard's Avatar
jack orchard
Me, Too
I agree. An aftermarket cruise would be easy to install, and almost invisible (and new).
I use 2 simple momentary switches; one for set and one for resume.
Buildingdavej
15
Aug 26, 2025 01:53 PM
Celticcitation
16
Sep 26, 2020 02:10 PM
pedrorairez
39
Dec 19, 2017 07:51 PM
704 dentside man
Oct 5, 2013 12:50 PM
rayf100
May 25, 2006 03:08 PM
