SCMT question
Old Sep 7, 2003 | 06:42 PM
ehagerty's Avatar
ehagerty
SCMT question
I have been running the tow safe program since purchasing the 1705......
My question, is it ok to run the "Hi-PERF Tuning" program with out any other mods or guages if I am not towing?
Thanks for your help...
Old Sep 7, 2003 | 08:48 PM
Michael013's Avatar
Michael013
SCMT question
I run the perf tow in mine, it's plenty of power.
Old Sep 8, 2003 | 09:05 AM
Carfunkel's Avatar
Carfunkel
From: Canterbury - A beautifu but overpriced rural setting in central NH
SCMT question
Is it OK? I would have to answer that it is OK as long as you don't hurt anything - which is sort of like saying that its OK to play with handgrenades so long as they don't go off.
Any chip is going to increase power by adding more fuel. Fuel + air = power. Without the fuel, you can't get more power. Added fuel also means added heat. Without gauges, are you willing to take the chance that your EGTs don't go too high? Sure, guys do it and get away with it, but how do you really know? Running unloaded will keep the EGTs lower than if you were hauling a load, but will they always be safe if you're dumping in extra fuel?
Spend your money on the gauges first. Even with an unmodified engine, an EGT gauge will help you to drive it more safely and more efficiently. After that, then do the exhaust and intake modifications. These will give you more power by reducing the pumping losses of the engine as well as keep the EGTs lower which will lead to increased efficiency. They won't give you the kick in the pants feel of a 60 -100 hp chip, but you KNOW they are safe.
Then, and only then, get the chip. Again, you're going to hear a lot of anecdotal evidence that what you are proposing is safe. But how many of these folks are going to help you foot the bill if you cook your engine and Ford finds evidence (like cleaned contacts where the chip plugs in) of a power enhancing modification that they did not approve? Your dime - your decision. Are you willing to be your own warranty station?
Old Sep 8, 2003 | 09:42 AM
johnsdiesel's Avatar
johnsdiesel
SCMT question
Ditto what Carfunkel said. You should have gauges, intake, and larger exhaust before you start cranking out the power. There's a good chance that the temps could get too high if you don't.
Old Sep 8, 2003 | 10:25 AM
Michael013's Avatar
Michael013
SCMT question
I have never had any problems with the programmers and Ford Warranty. Our Ford dealer even sells Hypertech programmers. What is considered a "safe" exhaust temperature? I removed my Hypertech, which was weak. I use the SCMT on perf tow, medium setting and it gives plenty of power. I used a remote(wireless) strap-on thermister sensor, on the exhaust pipe in various locations and even at full throttle no temp was ever over 900 degrees. (only was 78 to 83 outside). If you tow I am sure it would put your EGTs much higher and if it is hot outside even more. Using the SCMT on the high setting did make the EGTs go over 1000 degrees +. So I choose to run it on medium with no towing, it gives plenty of power on that setting. I do have the Ford Severe Duty intake 2U2Z-9K635-AA.
I keep hearing mixed comments on the exhaust. I measured my along my downpipe with a caliper and it is about 3.27" average. I have a 4" downpipe ready to install to connect to the rest of the 4" exhaust system. Does the downpipe have to be smaller than the rest of the exhaust system? Because of the turbo?
Old Sep 8, 2003 | 02:08 PM
RRMike's Avatar
RRMike
SCMT question
Safe EGT would be less than 1300 farenheit pre turbo. Any hotter than that and you will start melting the turbo. Definately get a pyro and intake. The exhaust helps too but the way to keep EGT's low is to not overfuel. When you dump a lot of fuel you need to allow more air to keep from overfueling which pushes unburnt fuel into the exhaust where it burns creating a massive increase in EGT.
If you see black smoke (more than just a bit when first accelerating) then you're overfueling and probably have higher than normal EGT.
Old Sep 8, 2003 | 03:31 PM
Carfunkel's Avatar
Carfunkel
SCMT question
Wrong, Wrong, Wrong!!! Your pistons are aluminum, your turbo is steel, probably a high grade stainless. Check out the melting point of these two metals. When your pistons are turning to soup, your turbo is just barely getting warmed up.
"It aint what you don't know that bothers me, it's what you know fer sher that just aint so." ~ Mark Twain
Old Sep 8, 2003 | 07:04 PM
RRMike's Avatar
RRMike
SCMT question
http://www.galebanks.com/Tech_whyegt.cfm
I'm going by what they said in this article by Gale Banks. Aren't the pistons cooled from below with oil??
Old Sep 10, 2003 | 08:39 PM
FTE Ken's Avatar
FTE Ken
SCMT question
There are no contacts to clean with a tuner.
Old Sep 10, 2003 | 08:44 PM
FTE Ken's Avatar
FTE Ken
SCMT question
No, he is right, right, right!!!!
You can keep the Powerstroke at 1250 all day long. 1275-1300+ for bursts (prolonged exposure of the turbo to 1275+ means it starts absorbing the heat and the tips start to glow and flatten out). This is fact of the Power Stroke, not an opinion.
Old Sep 10, 2003 | 09:01 PM
ehagerty's Avatar
ehagerty
SCMT question
So does this mean I can run it safely if I am not towing at the 80 hp/130 tq without upgrade or guages? Or not........
Been using the 60 hp setting.....
Old Sep 10, 2003 | 09:12 PM
FTE Ken's Avatar
FTE Ken
SCMT question
Superchips says you can and they are right under most conditions. However, fuel quality, under hood temps, higher altitude and a host of other things can impact EGTs. I advise guages if you plan to run 80HP with any sort of extreme use (ie, don't gun it).
Old Sep 10, 2003 | 09:24 PM
ehagerty's Avatar
ehagerty
SCMT question
Thanks Ken......
Time for some shopping
Old Sep 10, 2003 | 09:39 PM
Michael013's Avatar
Michael013
SCMT question
What about if the outside temperature is low? Below 70 degrees.
shelbygt500_653hp
Sep 20, 2010 08:13 PM
Go Aweigh2452
May 22, 2006 10:35 PM
Monsta
Computer Chips & Tuners
Dec 16, 2005 09:04 AM
ford_prof
Sep 15, 2003 07:45 AM
