Duralift E-pump has Air in the Pre-filter housing
Recently, I noticed a bunch of air in my pre-filter on my duralift e-pump. It was usually about 10-15% air. It never seemed to affect performance, so I left it as is.
In the last week, I dropped my front tank to replace the fuel sender. Woohoo, now I have working front and rear tank gauges. Freaking FINALLY.
However, I checked the e-pump pre-filter housing and now it's 50% air. Still doesn't have any affect on performance, but seeing that much air is disconcerting. The really weird thing is, it only has air when it's idling. When I kill the engine, the prefilter refills with diesel.
I thought maybe I had an air leak on my new fuel sender and the e-pump was sucking air. However, it behaves the same on the Rear Tank when I switch the fuel selector. My e-pump is directly in front of the fuel selector on the rail, so there is almost no place for the air infiltration to occur. Perhaps the selector valve itself has a air infiltration issue, but IDK. Something tells me that I don't have an air infiltration issue.
Just to inform you, I have a custom schrader valve at the highest point right before the IP inlet. I purge the fuel system and there are no bubbles or air spirting out. I'm really confounded.
Another side comment, I bought the R&D IPI Performance Stage 1 filter setup. I was thinking that maybe there was a decent sized air bubble in one of those filters, that was maybe working its way back to e-pump filter housing. However, my stage 1 filter head is AFTER the e-pump, so I doubt it would let air bleed back from the filter heads against the flow.
Another idea I thought of was maybe the e-pump was creating a vacuum from my new fuel senders, thus the air gap (reduced pressure might make the fluid a gas) but I doubt the duralift is pulling that hard.
The thing that really bothers me is when I purge the air out of the schrader valve, it never spirts air and the pre-filter has no air when the engine is off. If it was sucking air into the pre-filter from somewhere, you'd expect the purge to show some air somewhere in the fuel lines. Any ideas?
The more I fiddle with this pump, the more I think I have a hole in my fuel line somewhere. It must be pulling air trying to suck fuel from the tank. But since it behaves exactly the same on the front or rear tank, that leaves the 12" fuel hose from the selector valve to the e-pump OR the selector valve itself.
But when I look at the fuel hose, the connections, and the selector valve, I don't see any seepage or any indication that my fuel lines are problematic. IDK. I can't figure out this crap.
Now the weirdness continues....
I checked the hose that goes from the selector valve to the e-pump. It is clear blue, so I can see the fuel in it. When I idle the engine, there is air in the e-pump housing, HOWEVER, when I shine a flashlight thru the blue clear line, there are NO bubbles.
Very very strange. I'd expect if there was air intrusion before the e-pump, then it would be sucking air thru the fuel hose, likely from a hole or leak somewhere in the line or connections. However there was NO air bubbles at all. That means if there was air intrusion, it probably is in the e-pump or the e-pump fittings or the e-pump seal pre-filter housing.
The fittings are tight and don't have any seepage at all, so I doubt that has a hole. maybe the pump has an air leak somewhere. IDK.
Still working on it.
Most e-pumps contain check valves even the janky Mr. Gasket 12D does...
Can you apply some pipe dope to the pump fittings? Would be easier than thread tape anyways..
Good ideas.
After tinkering with this for a while, I think there is an air bubble that cannot get out, because the e-pump is about the same level as the tank. I recently dropped my tanks to do some sender maintenance, and i'm thinking that since my tanks are near empty (only about 3-5 gallons in each), then maybe the fuel level is just matching what it is in the tank. So, I plan to fill them up tomorrow, then see if the air bubble rises.
Dave R.
07-24-2013 05:27 AM
macm
31
11-18-2007 03:30 PM
ernesteugene
03-05-2007 04:20 PM
