01 7.3 Fueling Issues
Old Aug 14, 2017 | 07:32 PM
ToddMyers58's Avatar
ToddMyers58
The first time happened about a moth ago and then again today
It seems like the truck is running out of fuel when there is just under a quarter on the gauge, it starts off as just a little rough in the idle and then gets progressively worse but doesn't kill the truck. When it gets worse it looses power and will barely move under its own power.
First time I replaced the ICP sensor as that was bad and it seemed to be fixed, but today it did the same thing when the gauge was around the same spot. I got someone to bring fuel and it ran fine after a minute or so of semi rough idle.
It seems that the gauge is off by 1/8 or 1/6, has anyone else experienced this?
Old Aug 14, 2017 | 07:36 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Search Hutch and/or Harpoon mod and your questoins will be answered.
Old Aug 14, 2017 | 08:00 PM
jhl3's Avatar
jhl3
Sous is correct and pointed you in the right direction.
There is a foot on the bottom of the fuel pick-up tube that becomes brittle over time and then breaks. When this happens, the overall length of the fuel pick-up tube is shortened by enough that the truck will become starved for fuel even though about 4-8 gallons of fuel remains in the tank which depends on which capacity tank your truck came with. It is not uncommon.
As you have already figured out, don't let the truck get below 1/4 of a tank until you address this.
Old Aug 14, 2017 | 08:25 PM
ToddMyers58
Thanks for the quick replies! I'll have to look into that
cateadams
Jan 23, 2014 05:08 PM
lllateralus
Jan 4, 2012 11:29 AM
diesel-fitter-bum01
Oct 14, 2011 10:43 PM
SNIPER168308
Sep 29, 2011 01:55 PM
cclc1021
Dec 31, 2010 05:20 PM
