Harpoon Mod Tool Question
Old Aug 14, 2017 | 08:10 AM
mtbraun's Avatar
mtbraun
Just installed the Hutch mod kit from Strictly Diesel yesterday, and at the same time was going to do the harpoon mod. The problem I ran into is that I looked all over town for a pvc cutter and couldn't find one. The specialty tool store was not open on Sunday so I need to check with them before ordering one online, but my question: What jaw size does the tool need to be in order to cut the filler neck hose? It is the larger of the two and need to be sure the tool is at least that big.
The largest I could find online was for 1 3/8 OD and that does not appear big enough for the filler neck.
Old Aug 14, 2017 | 08:16 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I want to say the plastic tube was about 1.5", but that was a while ago. I just went to Home Depot and bought the cheapest one I could find that I thought would fit. I am not sure, but I may have had to cut the tube from 2 sides if that makes sense.
Old Aug 14, 2017 | 08:33 AM
Colorado350's Avatar
Colorado350
Harbor Freight has one that will work.
Old Aug 14, 2017 | 10:01 AM
SaintITC's Avatar
SaintITC
I used the PEX pipe cutter I bought at Home Depot, not too large, wide jaws and ratchets. Cuts it like scissors.
Old Aug 14, 2017 | 12:11 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Cuts plastic and rubber up to 1 5/8".
Old Aug 14, 2017 | 12:47 PM
mtbraun's Avatar
mtbraun
Thanks for the help this gives me several options.
Old Aug 14, 2017 | 03:23 PM
Stebs's Avatar
Stebs
https://www.milwaukeetool.com/power-...rdless/2470-20
My PVC cutter of choice... I've even used it on 1/2" drip irrigation tubing... might be overkill for you though...
Old Aug 14, 2017 | 05:36 PM
brian42's Avatar
brian42
Veteran: Navy
Home Depot one is about $13 and will work for quite awhile. Harbor Freight is about $3 and works a few times.
I went the Harbor Freight route and it worked great for the Harpoon mod and for the project after that then it was done. Definitely got my $3 worth out if it.
Old Aug 14, 2017 | 06:02 PM
SaintITC's Avatar
SaintITC
I had the Home Depot one from installing PEX throughout my entire house 2 years ago, and it's now doing my daughter's home, a little bit at a time.. It's so simple, can't imagine why even HF can't make one to work..
Old Aug 14, 2017 | 10:03 PM
petrokiller's Avatar
petrokiller
Ace Hardware will have some PVC cutters.
If you know them they may let you borrow there's for cutting hose.
I am not 100% sure but I think I cut both PVC at the top of my tank.
One is vent the other is fill I believe.
Anyone else confirm witch Juan to cut??
Old Aug 14, 2017 | 10:30 PM
Keabler's Avatar
Keabler
Cut them both. If the vent stays long, then foam can still cause a slower fill.
Old Aug 15, 2017 | 06:42 AM
Walleye Hunter's Avatar
Walleye Hunter
I thought that only the vent tube got cut, do they both get it?
Old Aug 15, 2017 | 07:48 AM
SaintITC's Avatar
SaintITC
Yes both. If you leave the vent tube long, once the diesel fills past that, the air volume/foam will be forced up past the incoming fuel and/or it may push soild fuel up the vent, either one making a mess and ending your fill.
I cut them both as short as I could. With auto pumps I can use the full speed setting with no issues, on the truck pumps when it gets near full I slow it down as that one does splash when it clicks off at high speed. I've put 39 gals into my 38 gal tank a few times.
Old Aug 15, 2017 | 08:01 AM
mtbraun's Avatar
mtbraun
I'm a Milwaukee guy, but yeah that's a little overkill.
Old Aug 15, 2017 | 08:06 AM
mtbraun's Avatar
mtbraun
As an aside, after completing the Hutch mod I noticed no reduction in engine noise. Interesting that was one of the things many people have said they noticed. I disassembled the mixing chamber and the screens were about 50% plugged, as well as the pickup umbrella being about 20% plugged. I did notice an increase in seat of the pants power, which I presume was because it had been starved for fuel. I'm not concerned with the noise issue, but thought it would quiet down the motor some.
