Support for transfer case on 4x4
Old Aug 14, 2017 | 02:09 AM
perkint's Avatar
perkint
Welded to a slotted bracket attached to transfer case with existing bolts.
Other end. Considering adding a rubber grommet to absorb vibration.
I love this truck!
Got this idea from a well worn Idaho Highboy with a snowplow. Good upgrade that might save transfer case seals or overkill where the factory setup needs no improvement? Thoughts?
Old Aug 14, 2017 | 10:08 AM
fe390pc's Avatar
fe390pc
I know the 1973 to 1976 Highboys had this type of support. So I think you are good, I would replace your current mounts as they look home made. You can get a good set of poly transfer case mount from Prothane Suspension (Prothane Suspension Parts: F250, ford f250 4wd 1970), they also have several other parts for our trucks.
Old Aug 14, 2017 | 11:02 PM
RichS2659's Avatar
RichS2659
Yes, 73-77 F-250 NP-205's had a strut rod with rubber insulators, Hopefully Jeff or ND can show the drawing for the 73-77 rod with the insulators. My very late 76 crew doesn't have one.
Old Aug 16, 2017 | 03:05 PM
JEFFFAFA's Avatar
JEFFFAFA
Ian Clarke
Mar 25, 2019 04:58 PM
Jamesbognar22
Nov 25, 2017 06:26 PM
Koolkat
WTB - Parts & other
Apr 17, 2017 07:16 PM
Spankymeyer
May 5, 2016 03:03 AM
84 f250 6.9
Aug 23, 2009 12:18 PM
