Wire location help, please
Old Aug 12, 2017 | 04:38 PM
inthedirt's Avatar
inthedirt
Looking to wire up my backup camera and need something with an ignition cutoff under the dash. Currently, it's wired hot to a toggle that was installed by the PO. If left on, it has a 5a draw. Seeing how the Mrs is taking it on a girls trip to Mt Shasta for a week, I don't want a call saying the battery went dead overnight. Any help is appreciated
Old Aug 12, 2017 | 05:09 PM
projectSHO89's Avatar
projectSHO89
What is it that you are calling "an ignition cutoff"?
What, specifically, is this vehicle?
Old Aug 12, 2017 | 06:14 PM
inthedirt's Avatar
inthedirt
A wire that is only hot when the ignition is on
Old Aug 12, 2017 | 07:03 PM
metru's Avatar
metru
isnt backup camera meant to be hooked to the wire that powers the reverse lights? that way it only turns on when your in reverse an shut off otherwise? least thats how mine is showed in the instructions
Old Aug 12, 2017 | 10:14 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
We need to know what vehicle and year you are installing this on. 00 & 01 are different from the 02-05 trucks.
Old Aug 13, 2017 | 09:55 AM
inthedirt's Avatar
inthedirt
This is on my 2000. The camera itself receives a power feed from the reverse lamps but the monitor needs power. The 12v aux and cig are hot with key off, so I need an alternative ignition-controlled source.
Old Aug 13, 2017 | 09:57 AM
inthedirt's Avatar
inthedirt
Forgot to mention that the camera sends a wireless video signal to the monitor. If it were wired, I'd just use the same reverse lamps source. But alas, it is not. I need a switched hot wire for the monitor.
Old Aug 13, 2017 | 10:16 AM
mecdac's Avatar
mecdac
Tech Thread Search Wiring Diagrams
Old Aug 13, 2017 | 10:19 AM
alloro's Avatar
alloro
See the attached PDF.
File Type: pdf
Old Aug 13, 2017 | 10:31 AM
inthedirt's Avatar
inthedirt
Thanks, that helps a ton
ChiefGeek
Aug 11, 2017 10:11 AM
youngone1234
13
May 1, 2016 04:11 PM
HARALSON COUNTY
1997 - 2003 F150
May 16, 2015 07:49 AM
those70'sfords
Electrical Systems/Wiring
Dec 16, 2007 06:32 PM
buckshot047
Jun 1, 2007 02:53 PM
