Resistor wire
Old Dec 12, 2007 | 05:01 PM
those70'sfords's Avatar
those70'sfords
Angry Resistor wire
<TABLE><TBODY><TR><TD vAlign=top width="100%">I need help!
I was trying to install aftermarket power windows, and in doing so I did not realize that I had "spliced" into the Resistor wire that runs from my ignition switch to my control module.
I ended up ruining the insulation from the ignition terminal to where I had the splice (about 1.5" in length).
I did not realize till after I made the mistake that this particular wire (red/green) was labeled " DO NOT CUT OR SPLICE".
What is the best way to remedy the situation? I can not seem to find anywhere that carries this type of wire and i sure don't want to re-wire the entire truck!
I hope someone out there has run accross this and can help.
Thank you in advance.
</TD><!-- KEN: 1-13-2007: show 300x250 ad-block to non-Club FTE users in the 1st post of every page --><!-- Ken 2-8-2007: only if not club fte member in --><TD vAlign=top align=right width=300>
</TD><!-- / Ken, end of hack --></TR></TBODY></TABLE>
<!-- / message --><!-- no sigs except when logged in --><!-- sig -->
__________________
Old Dec 12, 2007 | 09:51 PM
marks69's Avatar
marks69
i melted mine the other day. went to part source and they had one in the help section. was about $5 then just put it in .
i tried ford and they said it's discontinued. suprise.
gl
mark
Old Dec 13, 2007 | 10:12 AM
those70'sfords
Thank you.
Did everything work out o.k?
Old Dec 13, 2007 | 10:31 AM
marks69's Avatar
marks69
seems to be ok. i also fried the one on the start sel. my battery charger had a booboo.
Old Dec 15, 2007 | 02:04 PM
those70'sfords
I found the reistor wire at a salvage yard off a 1978/1979 ford pickup.
I went ahead and crimpped/spliced in a piece of about 4.5".
The truck seems to be starting and operating fine except that said wire is warm to the touch!!!!
Is this normal? Is this safe?
Old Dec 16, 2007 | 06:32 PM
Franklin2's Avatar
Franklin2
Yes it will get warm. Just so long as it doesn't get hot enough to melt the insulation, you are ok. Most all factory stock vehicles had a resistance wire up into the late 80's.
02sd
Dec 21, 2015 03:29 PM
LostMayhem
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jan 9, 2008 12:17 AM
volcom_inc
Dec 8, 2007 03:38 PM
Augusto1963
Engine Swaps
Oct 4, 2007 07:34 PM
uncle2abc
Paint & Bodywork
Mar 4, 2007 10:46 PM
