Loping at idle
Old Aug 13, 2017 | 11:05 AM
z31freakify's Avatar
z31freakify
The only time I've seen this problem as well was with one of the work trucks, it turned out the armature clearance on one of the injectors was way out of spec not even a .001 filler gauge would fit, shimmed it and the lope went away and all was well.
Old Aug 13, 2017 | 11:12 AM
Colorado350's Avatar
Colorado350
Originally Posted by Kamstutz
I checked the fuel pressure and it was 55 lbs. It doesn't seem to be a fuel problem. Since I can start the truck one moment (waiting for the wait to start light to cycle) it runs fine and the next moment I start the truck (not waiting for the wait to start light to cycle) it romps really bad. I can switch the sequence at any time with the same results.
Okay, just for reference, I also have the fuel crossover and a new pump my pressure is at 71. I've seen it dip to 67-68 when towing here in CO. Good luck figuring this out!
Old Aug 13, 2017 | 11:25 AM
andym's Avatar
andym
I have the original pump and an FRx and I get about 62 at idle. I've seen it dip as low as 57 under heavy throttle going up a long steep hill in OD.
Old Aug 17, 2017 | 12:30 AM
retiredsparky's Avatar
retiredsparky
Agree with getting a scanner. Auto enginuity or torque pro. In my opinion, everyone who has one of these trucks and likes to do their own work should be able to scan for codes and read the essential available information from the engine. It makes it so much easier to both do your own troubleshooting and also ask for help on this forum. Guessing gets really expensive.
Larry
Flame Out
19
Nov 14, 2017 08:18 AM
troverman
6.7L Power Stroke Diesel
28
Nov 23, 2015 07:11 AM
F350mikey
Dec 23, 2012 09:19 AM
Mike Bartlett
Dec 28, 2010 01:42 PM
johnboggs21
16
Feb 12, 2010 02:11 PM
