Wait To Start...when?
Old Dec 28, 2010 | 12:15 AM
Mike Bartlett's Avatar
Mike Bartlett
Hi All,
I guess when my uncle got me into Ford Diesels it was back in the mid 80's with the 6.9L, boy not a speed deman. Anyway he always said do not start a diesel until the Wait To Start light goes out, summer/winter didn't matter. I also heard at some point you could break GP by not waiting?
As I read some threads here is seems that may not be true? So what's the scoop? When should I or shouldn't I wait for the Start light to go out?
Thanks...
Mike
Old Dec 28, 2010 | 12:20 AM
Skip1970's Avatar
Skip1970
sounds like crazytalk to me.
Old Dec 28, 2010 | 01:01 AM
JamesHajek's Avatar
JamesHajek
Yep, Not exactly true although effective. The wait to start light is a dummy light and doesn't actually show the time that the glow plugs stay activated. They can stay on up to 2 minutes depending on EOT and outside temp. When you turn the key to ON, the WTS light comes on for about 10 seconds and then goes out, however you gp's will stay on even after the truck is started to help clear up smoke. If its summer time and 80 degrees outside, and you pull up at the fuel station. When your done filling, you can jump in the truck and just turn the key, it wont hurt a thing. The colder it is outside, the longer you should wait to start it, Maybe 30 seconds. I don't think you can break a glow plug by not waiting til the light goes out. Remember, its just a dummy light. If you want the real scoop on if the gp's are activated, Run out to your truck, turn the key to ON and watch your voltmeter drop down...When that pops back up 1-2 minutes later, your gp's just turned off.
Old Dec 28, 2010 | 08:09 AM
RubberDuck's Avatar
RubberDuck
Since I'm in TX I rarely wait for the glow plugs or the light. If it's above 40 degrees, I'll jump in and crank it right away. Never had any issues what so ever. However, each truck is different. You have to learn your truck. If you hop in and try to fire it and it sputters, but then let the glow plugs cycle and it fires..... you know if it's that cold or colder, you need to wait. etc. etc.
But to answer your questions, NO, you will not hurt a thing by not waiting on the wait to start light.
Old Dec 28, 2010 | 09:22 AM
Talyn's Avatar
Talyn
The Glow plugs stay on if you wait or don't wait for a minimum amount of time based upon oil temperature of the engine.
Glow plugs assist with cold startups, and assist with chamber pressure during warmup for at least 2 minutes.
So, if you get in and crank right away or not, they are still going to be on.
I wait for the start light in the summer 50% of the time. If its the middle of the day, I jump in and go. If its early morning after night I wait for the light. But my motor seems to be a bit temperamental on start-ups.
Starting without waiting for the light and having sputters and coughs can just be a sign of failed glow plugs or wiring, or even GPR.
In a way, starting without waiting for the light can be considered a diagnostic tool in some rare cases.
But no, your not going to break anything, but unless you are in warm climates like RubberDuck, not waiting wont help you much.
Mine is on for 30 seconds in the morning right now when starting.
I'm definitely waiting.
Old Dec 28, 2010 | 11:07 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Just an observation, when I installed my chip, the WTS ligth reduced the time of staying ON, and I have read that other members has noticed the same thing, and BTW in the same wheater conditions than before the chip installation, does anybody can explain that?.
Old Dec 28, 2010 | 11:43 AM
Mike Bartlett
Thanks guys, I get it now at least I know when my daughter occasionally drives my truck she won't break anything when starting it I think getting her last text in is more important than watching the WTS light?
Just got my new Stancor GPR I am hoping I can get it installed today?
Mike
Old Dec 28, 2010 | 11:48 AM
JamesHajek's Avatar
JamesHajek
You will love the stancor. It is a great product. Takes all of two minutes to install. Just remember it wont sit the exact same way as the original GPR. Doesn't matter. And the wiring doesn't matter either, Long as the big wires go to the big lugs and the little ones to the little ones.
Old Dec 28, 2010 | 01:36 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Yep.
The base programming in the chip isn't the same as the base program in the PCM. For instance, a NAW4 PCM will keep the "Wait to Start" light on quite a bit longer than a TDE1 program will....which is what you have now if you have an automatic transmission.
There's nothing wrong with your truck now with the shorter "WTS" time. It's just in the programming.
Old Dec 28, 2010 | 01:42 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Originally Posted by cleatus12r
Yep.
Cody,
Thanks for your input, and Im certanly that theres nothing wrong with my truck, just was an observation, now confirmed for you. And yes my PCM is NAW4.
