Need some ideas rough running when cold
Old Aug 11, 2017 | 09:45 PM
Hey351's Avatar
Hey351
Have a 1990 5.8 F250 manual. Super clean truck only 115k on it no rust so she needs to run again. She starts up but very quickly surges then drops the tach is jumping around. If I floor it it sputters but never dies out just sputters. If I try to drive it there is no power same rough sputtering mess. After about 10 minutes tho it starts to smooth out and runs fine. Mileage is down maybe 7-8 mpg. Plugs are new, TPS new, IAC new, cap rotor dizzy and wires are new. Engine Temp sensor getting 22k ohm when cold didn't test it hot or warming up Any ideas let me know Im going to test for vac leaks in the am as just got the tool tonight but visually I checked all and everything looks good. One note is my dizzy crapped out in the fall and it sat all winter spring and just fixed that issue to have this issue. Fuel filter is only a year I put fresh gas in with a can of seafoam so gas should be good I've burned through 6 gallons so far
Old Aug 12, 2017 | 08:57 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Before you threw money at it did you check for trouble codes?
Old Aug 12, 2017 | 09:45 AM
Hey351's Avatar
Hey351
No CEL and code reader not picking anything up. Maybe it's not working have the basic $25 Ford reader.
ratzmann36
May 13, 2011 09:08 AM
kdokey
Dec 29, 2009 12:36 PM
geodiggr
Aug 31, 2009 12:34 PM
happycrab
Feb 17, 2008 08:03 PM
hunter27
Feb 14, 2007 09:09 PM
