running cold
Old Feb 12, 2007 | 06:42 PM
hunter27's Avatar
hunter27
running cold
Hi guys I got a question my 5.8 is running on the cold mark after you drive it for miles and let it idle. It runs very rough like this and stalls sometimes. It also shows a check engine light sometime but goes off after a couple of seconds. would this cause it to run rough not getting warmed up also it does throw heat.
Thanks Hunter
Old Feb 12, 2007 | 09:47 PM
sivart's Avatar
sivart
I'd throw a thermostat in it. Cheap and easy. If that doesn't do it maybe one of the smart guys in here know. Might want to include what year it is.
Old Feb 13, 2007 | 06:13 AM
hunter27's Avatar
hunter27
Sorry it is a 1993 Bronco
Hunter
Old Feb 13, 2007 | 09:15 AM
Kemicalburns's Avatar
Kemicalburns
PULL CODES. www.fordfuelinjection.com will show you how.
repalce the tstat with a 195* and replace the engine temp sensor as well but only after you pull codes an report what you find. your gas mileage is probably sucken right now to huh?
Old Feb 13, 2007 | 09:38 AM
d79f150's Avatar
d79f150
Check your oil for signs of antifreeze, and check your antifreeze for signs of oil. You make have a cracked head or a bad head gasket.
Also check for signs of fluid leakage around the intake - common problem with older ford V8's
Old Feb 14, 2007 | 03:55 PM
hunter27's Avatar
hunter27
I put a thermostat in and that seemed to take care of the problem.
Thanks Hunter
Old Feb 14, 2007 | 09:09 PM
sivart's Avatar
sivart
Talking
Cool. I wish I could solve my problems that easily.
