fuel problem????
Old Sep 18, 2003 | 07:02 PM
  #46
HAZBRZ's Avatar
HAZBRZ
fuel problem????
Decided that maybe the line going to vaccum advance was loose inside the fitting so I got the stuff to use rubber line instead of the rigid...After putting that on and movind the dist to close to where it was before I started It fired up perfectly...UNBELIEVABLE...IT WILL RUN GOOD (revving up also)FOR ABOUT 4 OR 5 MINS THEN ACT CRAZY AGAIN. I let it cool off and it started good again...could it be a bad distributor??? I'll change the points for kicks again but after I check for any weak wires I was going to try a new dist...What do ya think??????
Old Sep 18, 2003 | 08:18 PM
  #47
willowbilly3's Avatar
willowbilly3
fuel problem????
It sounds electrical. Condenser seldom go bad but it sounds like that or a coil. Try the condensor first, coils are pricey.
Old Sep 18, 2003 | 08:45 PM
  #48
brewster's Avatar
brewster
fuel problem????
I don't know if the compression is low I can't see how it can run good. If you have a lot of oil or dirt around the coil it can arc and make it run bad. If you have a different distributor I would try that. Sometime they go bad .
brewster
Old Sep 18, 2003 | 08:52 PM
  #49
brewster's Avatar
brewster
fuel problem????
Also try running a wire from the pos. on the bat to pos on the coil.
Brewster
Old Sep 22, 2003 | 11:36 AM
  #50
HAZBRZ's Avatar
HAZBRZ
fuel problem????
I cant believe it. Went and got a new condenser (like $2) and put it on and startrd and set timing and it runs perfectly...Smokes some when I start it but thats another issue. For some reason when I worked on it the last two times I went to work totally relaxed as if I knew I was about to get it right...After new vaccum lines and it started and idled I could breathe and didn't have to use any cuss words...Anyway thanks to everyone who read up on this and pitched in. I really appreciate you all.
THANKS, JERRY
Old Sep 22, 2003 | 06:04 PM
  #51
brewster's Avatar
brewster
fuel problem????
Good to hear . I know how you feel but all you can say is at least it's running now. I have had things like that happen to me .
Brewster
Old Sep 23, 2003 | 03:17 PM
  #52
simenad's Avatar
simenad
fuel problem????
Check for play in the distributer. I always had a bad hesitation and stumbling. Then one day I swapped the points for an electronic item and the hesitation quit. I then checked the old distributer and that was when I noticed that it only had a little play but it was enough to cause havoc that couldn't be found until after I gave up.
oldford65
Jul 23, 2013 10:17 PM
Spktyr
Jun 13, 2012 08:31 AM
DSMMH
Feb 19, 2010 10:03 PM
JHoffman93
Jun 28, 2009 11:08 AM
rlh
1978 - 1996 Big Bronco
Dec 17, 2003 06:20 PM
