Throttle adjustment question, '55 239
Old Aug 9, 2017 | 03:50 PM
Jeffro55's Avatar
Jeffro55
Well, I'm on the road! running strong on the original Y block & carb (to my knowledge, lol) and stopping confidently with the help of a dual reservoir master cylinder on stock drums. Just need to wire up the brake lights
I've been driving around the block a bunch & something I've noticed is that there seems to be only a small amount of pedal travel between idle and WFO. Leads me to wonder if there's an adjustment that can be made somewhere where there's a bit more leniency for a first-time manual transmission user!
I'm happy to provide more info, and as always, advice is appreciated!
Old Aug 9, 2017 | 07:29 PM
CBeav's Avatar
CBeav
Check all your linkage pivot points. It's a matter of length to pivot (just like gears) that can increase/decrease the travel.
Old Aug 10, 2017 | 08:23 AM
petemcl's Avatar
petemcl
Is everything stock? Lokar pedals have an adjustment.
Old Aug 10, 2017 | 09:35 AM
Jeffro55's Avatar
Jeffro55
Yes, everything is stock. I don't even know if it's normal, but I figure there should be a bit more travel in the pedal
Old Aug 10, 2017 | 11:30 AM
petemcl's Avatar
petemcl
You should check it by having someone hold the pedal to the floor (engine off) and the look at the position of the carb linkage. Then pull the linkage off the carb the operate the carb by hand and see if there is a difference.
oldmerc
Oct 15, 2015 07:37 PM
bulla
Jan 15, 2012 07:48 PM
dixokai
Oct 8, 2009 09:08 PM
TFagerholm
Jun 9, 2009 10:42 AM
Tekrep
Jan 16, 2004 08:40 AM
