Another dying while driving thread
Old Aug 8, 2017 | 08:45 AM
dieselsubmariner's Avatar
dieselsubmariner
Friend of mine has a 2005 F250 4x4 6.0 . 220.000mls
couple month back the truck all the sudden started running rough. next day running fine, then running rough. A&E Software check came up with several injectors misfiring and Ficm issue.
We replaced the Ficm and truck ran fine for about 1 month.
No while driving it happened several times that the truck shut off. no reason found, no issues. first couple times it cranked right up after a little time, last time they towed it home. Cranked up the next day fine.
A&E shows no codes, HPOP has about 800psi pressure while starting.
Any suggestions of what to look for? KOEO and KOER test reveled no problems either.
thanks for any advice.
Old Aug 8, 2017 | 09:02 AM
TooManyToys.'s Avatar
TooManyToys.
First, make sure the FICM connectors are fully clicked into the replaced FICM.
Old Aug 8, 2017 | 09:41 AM
dieselsubmariner
We will double check on that. Thank you
Old Aug 8, 2017 | 09:14 PM
Per4mance's Avatar
Per4mance
Did you change the FICM relay?
Old Aug 9, 2017 | 06:31 AM
dieselsubmariner
the Ficm relay is still the original. wasn't aware of those could go out intermittently. we will replace it as well. thank you
Old Aug 9, 2017 | 07:54 AM
TooManyToys.
It's good preventative maintenance to do so every 100k miles, or after you've had a FICM issue.
6ohStroker
May 22, 2018 05:21 AM
tuskfire8
Texas Chapter
Nov 29, 2012 02:51 AM
Killin Time
May 2, 2012 12:01 AM
mvedepo
6.7L Power Stroke Diesel
Apr 8, 2011 09:40 PM
cwb
Feb 22, 2005 07:59 PM
