I have a 2001 Ex 7.3. It started running rough for about 20 mins and cleared up. No check engine light came on but I pulled codes from it. I got the P0605 code and several others.
I have never had any issues with it running until then. The rough running cleared up for 2 days and then it started again for about 30 seconds and died. Now it will crank sometimes but runs real rough. Any suggestions?
Sounds like one of your problems might be an injector. Once they get heated up they unstick and work fine. Does it always take a bit before it starts running right?
Reason: more info
