Most common "No code" idle issues
Old Aug 20, 2017 | 08:59 PM
BLADE35's Avatar
BLADE35
You are e first person I've seen get
​​​​​​​a misfire count from SGII FOR a specific cylinder
will you post the code you used to program
​​​​​​​Is the count still there upon restart of vehicle??
We had talked about someone forcing a misfire to see if it worked but I don't think it ever happened
Old Aug 20, 2017 | 09:00 PM
navistarnut's Avatar
navistarnut
Nice! Those electrical things can sure be pesky at times on these beasts.
Old Aug 20, 2017 | 09:12 PM
Simps's Avatar
Simps
So do I win a prize? I will get the code I used to program it in the morning direct from the device and post it. You know, I did not check to see if it cleared when I restarted it. (I cycled to other gauges once I determined 5 was the culprit )
​​​​​​​I will check that too.
Old Aug 21, 2017 | 12:37 PM
Simps's Avatar
Simps
Here's the code ai used. The count did dissappear upon restart.
Old Aug 21, 2017 | 12:58 PM
BLADE35's Avatar
BLADE35
Thanks just what I wanted to know
Old Aug 21, 2017 | 03:18 PM
Kemicalburns's Avatar
Kemicalburns
I too have experienced a rough idle after towing long distance. I plan to change the fuel filters to see if that helps, they have about 30k miles on them at least.
i will look at that hose to see where it lays on the harness if at all.
Old Aug 21, 2017 | 04:00 PM
navistarnut
30k miles is 3x the life of those filters.....just sayin. Could result in lower than normal fuel pressure.
Might not hurt to pull the side cover off the HFCM, might find some gunk there that will likely not flush out with the drain plug removed.
Old Aug 22, 2017 | 10:07 AM
Kemicalburns
I had a feeling I was past the typical change interval. anything i need to be aware of when pulling that cover? is it wise to pull the filter first to relieve pressure? is there any gaskets that i may need as well? what do you use to clean out the HFCM if infact its dirty?
Old Aug 23, 2017 | 09:35 PM
navistarnut
I would just open the drain up first then take the filter out. The only way you will know if it's gunked up is take the side cover off, I would have a gasket on hand yes. Good time to get the updated drain plug as well if you don't already.
Old Aug 25, 2017 | 11:40 AM
Kemicalburns
can i get the updated drain from ford? I'll have to go by there to get the gasket anyway.
sorry for the HiJack
denden11
1997 - 2003 F150
Oct 27, 2014 04:11 AM
rayezra
Jul 16, 2013 09:48 PM
Carlos2
1997 - 2003 F150
Mar 13, 2012 07:49 PM
eric777
Dec 4, 2009 10:24 PM
captian diesel
Mar 11, 2005 01:32 PM
