Painted two bar grille
Old Nov 9, 2017 | 04:55 PM
  #61
cficare's Avatar
cficare
Sorry I mentioned it now. I'm not going to ship this thing ... too much trouble to protect it while in transit.
Old Nov 9, 2017 | 04:57 PM
  #62
Wesrern star's Avatar
Wesrern star
No worries I travel that way quite a bit if I'm up in your neck of the woods I'll give you a shout see if you still got them
Old Nov 9, 2017 | 06:31 PM
  #63
VTBulldog's Avatar
VTBulldog
Originally Posted by Wesrern star
Thanks, The white is a nice look. I think the Caribou bars are a bit too much on mine, but if I were to go with the Platinum Grill then paint Caribou, it would have enough break up in the color.
I photoshopped a platinum grill in caribou color on the same KR.
Not my best work, but gives you an idea......
Old Nov 9, 2017 | 07:28 PM
  #64
Wesrern star
Thank you,
I think that looks the best. The Platinum Grill with the holes works. The KR Bars don't get enough variation and it looks plan. but anyway I appreciate you help you've help me out a lot ...
thanks again
Old Nov 9, 2017 | 07:45 PM
  #65
VTBulldog's Avatar
VTBulldog
No problem man, anytime.
Old Nov 10, 2017 | 09:37 PM
  #66
Wesrern star
Just messing around with the top and bottom trim and blacked out the ford. Your Thoughts.
Old Nov 10, 2017 | 09:55 PM
  #67
17f250ford's Avatar
17f250ford
I photoshoped my truck to this
I think it looks good..
My truck has crome bumpers and grille
Just color matched with PS
Also i deleted the yellow from.the headlights
Old Nov 10, 2017 | 10:16 PM
  #68
Wes Hightower's Avatar
Wes Hightower
Originally Posted by cficare
Looks better than a two-tone grille ...
That would look better with the Caribou on the top bar and the white on the bottom.
Old Nov 11, 2017 | 07:46 AM
  #69
VTBulldog's Avatar
VTBulldog
Good start man! What program are you using? I use Pixelmator on my MacBook Pro ( Pixelmator Pro). When I open up a picture, I start with adding a "duplicate layer".
To select the paint color, I use the "eye dropper" which is a color selector. Look at your picture carefully to see where the sun is hitting your object, and click on the shade you want (also, you can pick the solid color in the brush setting, along with the size of brush you want to use.
Then go to your paint brush and adjust the "opacity" so you can change the color, but still see the body lines through it. Click to start painting, but I have to keep it pressed down, with one hand, while I am painting with the other, it's ok if you happen to go outside the lines, I will show you how to fix that. You can adjust the opacity depending on how light and dark you want the paint.
Once everything is painted, I cleanup all the overages that should not have paint on it. Click on the "eraser", and move this around to clean up the image. Since we have already added a duplicate layer, this cleaning will only erase the painting we did.
For example, paint the Ford emblem all at once, then zoom in, and erase what you don't need painted. All of this works best with the largest pixel pictures you can get, especially when you zoom in, keeps the pixels small and workable instead of big blocks of ****.
Once you have finished painting and are ready to save it, click on the "layers" tab, and then click on "merge layers". Then click on save, and it should give you multiple options. I use the JPEG version.
Have fun with it, and let me know if you have any questions. I can also explain how to add items to the picture, for example how to change rims, or add extra lights.
Old Nov 11, 2017 | 08:18 AM
  #70
Wesrern star
Nothing fancy just my note 3 phone. I have very little experience with computers or photoshop. But thank you. I'm sure I can learn a few tricks from you. I've seen a lot of your work and it all looks awesome.
Old Nov 11, 2017 | 08:52 AM
  #71
VTBulldog's Avatar
VTBulldog
Nice work man!
Old Nov 27, 2017 | 11:44 AM
  #72
LiquidSteam's Avatar
LiquidSteam
Originally Posted by justanotherday
Plasti dip for now until I decide to change the grille out. Completed about 1 month ago, so far no issues.
How do you remove the grill?
Old Nov 27, 2017 | 03:46 PM
  #73
cficare's Avatar
cficare
Old Nov 27, 2017 | 03:55 PM
  #74
TufLuk13's Avatar
TufLuk13
I like the caribou grille but I'd make the ford Logo the same caribou and the background white
Thurter
May 29, 2017 01:18 PM
beernutz09
2004 - 2008 F150
Feb 22, 2010 07:05 PM
mbogosia
2004 - 2008 F150
19
Apr 23, 2007 08:03 PM
Martin.Auto-Image
1997 - 2003 F150
Mar 13, 2007 08:34 PM
fordbronc399
1978 - 1996 Big Bronco
Nov 17, 2006 07:58 AM
