GEM plug wiring
Old Apr 10, 2020 | 11:44 AM
afonda's Avatar
afonda
Originally Posted by pirschwagon
I guessing this is what you want.
According to this diagram the GEM PIN #1 (on the A diagram) is for the washer pump. Would this hold true for a 2002 F250?
Old Apr 10, 2020 | 12:19 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
@afonda , I didn't think that the 2002 came with the GEM like the 2000 did, so I doubled checked my service manuals and it appears I might be correct.
GEM from the 2000 service manual.
VSM from the 2002 service manual.
Old Apr 10, 2020 | 01:35 PM
afonda's Avatar
afonda
well thats funny... when I run Forskin (haha) i always get a GEM Module error...
Sorry for the glare...
Old Mar 27, 2021 | 11:09 AM
axmrdr's Avatar
axmrdr
Originally Posted by jimjokjv
Okay, I'll connect the batteries in the morning, drive it for a while and then park it for at least an hour before checking battery drain.
I know this post is 4 years old but did you ever find the source of the current draw?
Old Mar 27, 2021 | 11:52 AM
jimjokjv's Avatar
jimjokjv
Yes, it was the glove box light.
One night I walked by the truck and saw this faint glow of light. Looked through the driver's door window and noticed it was the glove box light. The switch was no good so pressing it didn't shut the light off.
Old Mar 27, 2021 | 01:46 PM
axmrdr's Avatar
axmrdr
I'm glad you found it - I like happy endings.
I had something similar happen to me but mine was more obvious. I was out of town working and went out to the parking lot to a truck with dead batteries. The switch for the dome light in my rear driver side door stuck and kept my dome lights and truck bed lights on and it killed my end of life batteries. Sprayed a buttload of wd 40 in the door and worked the latch for 10 minutes. Replaced both batteries and it's been good ever since.
To this day I still check to make sure the dome lights go out.
Old Oct 11, 2021 | 07:11 AM
afonda's Avatar
afonda
Maybe because the build date of my truck is in 2001 it is different than that of a 2002 build date? I clearly have a GEM if I am getting GEM diagnostic code. Right?
Old Oct 11, 2021 | 07:45 AM
afonda's Avatar
afonda
I just went out and did a manual inspection... No GEM with the Fuse Box. There is a large black module behind the radio. I has 3 large wire harnesses plugged into the bottom of it. I am guessing this is the VSM (aka GEM)?
If it is not working right, is this a re-programming thing? or a replacement?
Andy
Old Oct 11, 2021 | 08:07 AM
Sous's Avatar
Sous
FTE Emeritus
We have seen some "mistakes" or "misprints" in FORScan literature and even how their PID tracking works. It is not entirely impossible to think this is a copy/paste from a 2000 MY.
Checking the Ford Service Manual on a 2002 MY with a VSM, the following came up for a P1832 and P1876 DTC.
PlainviewSpeedway
Electrical Systems/Wiring
Aug 4, 2020 07:11 AM
jimbbski
2009 - 2014 F150
Apr 2, 2017 11:50 AM
Benchwarmers6
2004 - 2008 F150
Jan 17, 2017 01:49 PM
Farmboypowerstroke
Aug 3, 2008 04:25 PM
HaroldCallahan
1983 - 2012 Ranger & B-Series
Sep 9, 2005 09:08 PM
