Very Random Stalling
Old Aug 7, 2017 | 10:50 AM
yasky69's Avatar
yasky69
This is a 2007, 143K F350
Sometimes will sit for a week before I use it.
It has a mind of its own. Some days it will start right up and if I put it in gear it stalls. I have to wait for the EOT to come up to normal temps. Yesterday I drove it to the store that's a mile away and when I pulled into a parking spot it just stalled as if I turned it off. Doesn't happen all the time.
I do use a scan gauge on it all the time.
Cold Start
Key on Engine off
IPR-14.81
ICP- 0
FICM 48
Start up
IPR-31.21
ICP-917
FICM 48
MAP- 14.6
ECT 90
EOT 82
As its getting warm
ECT 126
EOT 111
IPR 27.3
ICP 712
put into R and Drive
ICP- 711
IPR 25.3
In Neutral
Brought RPMS up to 2000
IPR 32
ICP 1000
FCIM 48
RPMS at 3000
IPR 49
ICP 1800
FCIM 48
Back to Park and ideling
ECT 164
EOT 155
IPR 23.8
FCIM 48
MAP 15
ICP 585
I'm trying to elimate ICP and IPR, Do these numbers look correct?
thanks
Old Aug 7, 2017 | 01:29 PM
Maxium4x4's Avatar
Maxium4x4
Is the truck tuned, if so, what is it?
High pressure pump readings.
You need to check fuel pressure at the Top filter port.
Old Aug 7, 2017 | 05:59 PM
yasky69's Avatar
yasky69
tune
It's not tuned as far as I know. Sounds it though. Checking fuel psi, good advice. I'll have to buy the stuff to do it since I'm not set up for the 6.0
Old Aug 7, 2017 | 06:16 PM
scarty111's Avatar
scarty111
My truck was doing that and my mechanic hooked it up and it said "poor FICM performance". So he took apart my FICM and we discovered there was a SWAMPYS FICM inside that was malfunctioning.Now I have a BFD 6 phase set at 53v FICM and all is good again.
Old Aug 7, 2017 | 06:22 PM
Maxium4x4's Avatar
Maxium4x4
One thing at a time guys.... Start with known parameters like fuel pressure, battery voltage, the simple over looked things in life to get a base line going. The port is Metric on the upper filter and I assume the fuel filters are up to date.
Old Aug 7, 2017 | 06:25 PM
Maxium4x4's Avatar
Maxium4x4
Usually but not set in stone, most will have a sticker on the outside to prevent tampering with the company logo on it. If we get down to the FICM and you have a friend to swap with, it doesn't get any easier to rule out a bad FICM.
Old Aug 7, 2017 | 06:29 PM
yasky69's Avatar
yasky69
stalling
Agreed. Ficm voltage has been consistent at 47.5 to 48. Battery voltage has also been consistent 13-14 volts.
I think I read I need a M12 X1.5 by 1/8 npt fitting to do fuel psi. Should be able to find that at napa
Old Aug 8, 2017 | 11:40 AM
yasky69's Avatar
yasky69
Once I get what I need to read fuel psi, I'll report back
Old Aug 8, 2017 | 12:09 PM
Simps's Avatar
Simps
Do you have a harbor freight close?
​​​​​​​They have a 25 dollar oil pressure kit that has all you need including the fittings needed to connect to test port on fuel filter housing
Old Oct 2, 2017 | 07:32 AM
yasky69's Avatar
yasky69
Bringing this back to life. A couple of things since this last post. I did learn about draining the water separator since this and because the "water in fuel" showed up on my display. So that's done. I had a injector fail on my (cyl 5) so that has been repaired.
I still get the "cold start" stalling when putting the truck into gear. So I'm thinking it has something to do with transmission or fluid. Level is good, as a matter of fact I had a the fluid replaced by ford.
So I'm wondering if there is some sort of transmission sensor, whether pressure or temperature that could make it stall until its warmed up?
Banjo250
1997 - 2003 F150
18
Jul 2, 2019 04:29 PM
navistarnut
Oct 19, 2018 01:53 PM
Mykelseychristine
Jan 6, 2017 06:54 PM
Randy 37
Jan 20, 2016 07:55 PM
flcracker9
Mar 3, 2013 07:13 AM
