rear hub seal help needed.
Old Aug 6, 2017 | 06:51 PM
white 66's Avatar
white 66
Hi Guys, I recently installed a new set of seals on the rear axle for my 1.5 tonner. The set I put on several years ago leaked very soon after driving the truck so I have ignored it until recently due to the accumulating mess. Anyhow started using the truck again and the new set leaks also.
Hubs are in good shape so are the housings (no groves). When test fitting the seals I noticed that they barely hug the axle. I know from the work I do with big trucks this is not correct. Possibly the seals are N.O.S. and have shrunk over the years.
Anybody know what a cross over number would be for the old rear hub seals # BB-1175-C might be? Stemco 2 piece or????
thanks.
Old Aug 6, 2017 | 08:30 PM
49fordv8f4's Avatar
49fordv8f4
Mark, The numbers are; National 5751 and C/R 31288. The National seal is leather like the original and the C/R is rubber. I've always used the National seal and had good service with them, although the rubber seal may fit a little tighter on the spindle.
Mark
Old Aug 6, 2017 | 11:02 PM
GB SISSON's Avatar
GB SISSON
I have always been told to soak the leather ones overnight in motor oil so they soften up and swell a bit. The rear axle seals I just put in my 1/2 ton were national and made of leather too. I think it's cool that something like that is still best made from animal hide.
Old Aug 7, 2017 | 12:13 PM
49fordv8f4's Avatar
49fordv8f4
I have always been told to soak them in oil as well. If I have time, I usually let them soak a couple of weeks, although overnite is probably long enough. Same with the front and rear main rope seals on the flathead.
Mark
Old Aug 7, 2017 | 01:48 PM
white 66's Avatar
white 66
hub seals (rear axle).
Mark
Thank you to both of you. I will go with rubber this time, don't want to have to do it a 3rd time.
Old Aug 8, 2017 | 01:05 PM
willowbilly3's Avatar
willowbilly3
I had a full floater on a daily driver I just could not get to quit leaking. The spindle looked fine but out of desperation, I eventually put a speedi-sleeve on and another new seal, it never leaked again, well over 100,000 miles on that seal when I parked it.
Old Aug 8, 2017 | 08:29 PM
GB SISSON's Avatar
GB SISSON
I second the motion. They aren't cheap, but they certainly are compared to a new axle housing and the labor to switch it over. Speedi sleeves can be a life saver.
Old Aug 9, 2017 | 04:42 PM
willowbilly3
Bad part is the installation tool is not made for the big spindle. I have had exhaust shops expand tubing to install the speedy sleeve and I have cut the center out of the installation cup to weld a piece of tubing on. Don't even think about trying to put one on without the right tool and don't get the cheap one without a lip for the installation tool.
BobQPublic
Jul 28, 2022 04:32 PM
fordbroncodave
Oct 26, 2012 10:19 PM
Hamberger
Oct 20, 2010 12:05 AM
SWMO F-350
Apr 1, 2010 09:53 PM
dslmn
Mar 30, 2010 03:04 PM
