Sponsored by: Real Truck
No power to ignition
Old Aug 6, 2017 | 03:16 PM
Ctxkiger's Avatar
Ctxkiger
I purchased a non running 2000 f250 with the v10 motor. The guy said he was driving it and it just died. That's all the info I got from him. It has power to main fuse box on fire wall. The fuse box under the dash is getting power as well. The items related to the ignition are not working. I swapped the actual key ignition with that of another truck and that's not the issue. I also replaced ignition switch with no change. Battery and cables are good. It's getting a full 12.6 volts to fuse box. Any ideas?????
Old Aug 6, 2017 | 04:37 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Not sure why, but did you copy that entire post from another web site? It came across with a bunch of eBay links embedded in it.
Old Aug 6, 2017 | 04:45 PM
Sam I Am's Avatar
Sam I Am
read this:
https://www.ford-trucks.com/forums/1...-no-spark.html
Old Aug 7, 2017 | 09:53 AM
Ctxkiger's Avatar
Ctxkiger
No i didn't copy it. I read that link and it's not the same issue. My truck will not crank nor is it getting power to items related to the ignition switch such as the radio or electric windows
Old Aug 7, 2017 | 10:32 AM
Sam I Am's Avatar
Sam I Am
So the starter will not turn? You will find that the more information you share about the problem you are having, the more likely you will get a workable solution.
Most people will separate the starter motor system from the ignition system, with the ignition system being the parts that provide the spark.
For a no start condition especially since power isn't getting to other things, you would start with a freshly charged battery, clean ALL the battery cable terminals, then proceed to verify power at the starter relay.
Old Aug 7, 2017 | 10:48 AM
krewat's Avatar
krewat
Well, 12.6 at the fuse box would indicate the battery is good and 100% charged.
Did you check ALL the fuses? Especially in the power distribution box under the hood? Pull all the fuses, and check underneath for obvious corrosion or heat-related issues (melted plastic).
Old Aug 8, 2017 | 09:21 AM
Ctxkiger's Avatar
Ctxkiger
I got the truck started yesterday. The problem is with the three block connectors that connect the wiring harness to the cab next to the computer. For some reason the connection are intermittent. I'm going to try replacing the wiring harness
Old Aug 8, 2017 | 10:01 AM
Ctxkiger's Avatar
Ctxkiger
Ryan Kovacs
Sep 29, 2016 01:36 PM
my4fords
May 2, 2016 02:41 PM
Asherron1
Jan 6, 2014 05:31 PM
mikefraz01
1978 - 1996 Big Bronco
Mar 19, 2005 03:40 PM
Oval_obsessed
Jul 1, 2004 08:28 PM
