No cranking
Old Aug 6, 2017 | 12:42 PM
ogarcia434's Avatar
ogarcia434
No cranking
My 1994 E350 up to now cranked the engine when I turned the key today all I get is a click. Checked the battery 12.42 volts. Turned the lights no lights.
What do I need to check to find the problem?
Thank You
Old Aug 6, 2017 | 04:19 PM
Sam I Am's Avatar
Sam I Am
Could be a bad starter relay. Could be a bad connection anywhere; battery, starter, ignition switch. Could be bad wiring, this year has been bad for mice chewing wires in this area.
I would start at the battery connections and check for corrosion. Then follow the battery cables to check and clean all the connections.
Could be a bad starter motor. Jumper across the relay before you dive into that.
Old Aug 6, 2017 | 07:10 PM
jimbomitch's Avatar
jimbomitch
The very first thing that I would do is disconnect the battery terminals and clean them.
Old Aug 6, 2017 | 10:27 PM
vettex2's Avatar
vettex2
This cures it 80% of the time
Old Aug 7, 2017 | 08:56 AM
jimbomitch's Avatar
jimbomitch
It's also the easiest and logical place to start
padd54
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 14, 2012 03:53 AM
GregAlex47
1983 - 2012 Ranger & B-Series
Dec 5, 2007 11:16 PM
gruntwannabe
Aug 10, 2006 08:19 PM
steve81
Jul 24, 2006 04:04 PM
brocobilliam
1978 - 1996 Big Bronco
Jan 2, 2006 01:47 PM
