what size of tires for the rear of my 67 f-100.?
i have a 67 f-100 2 wheel drive. i have lowered the rear using DJM shackle and their front spring lowering bracket in the lowest hole. i am planning to run Cragar SS wheels 15x8 on the rear how big of a tire can i use.? i like the look of the B.F. Goodrich Silvertown 285/70r15 not the whitewall version. would this be to big.? or should i run spacers to move the wheels out somewhat.? i talked to a guy at a car show yesterday. he said that he paid $ 800.00 just for the two rear tires in that size. i looked at summit racing. they want $225.00 each and its free shipping. he said that he bought them local.thanks for any help with this.
on
Sounds like a good size to me.
275/60R15 is popular, but they're still kinda small imo. So a 285/70R15 should fit well
285/70 would equate to about 31x11.50. I had a pair that size for awhile and they fit fine.
What do you plan on running in the front???
Personally, I like big tires. If it was mine, I'd look at maybe a 255/70 on the front
351Cleveland C4 thanks for the info. i am not sure about the size for the front yet. i am going to use Cragar SS 15x7 . i also have DJM Dream Beams for the front. they are supposed to lower the front about 3 inches. we will see. years ago i had a 67 that was not lowered and i ran Cragar SS 15x8 on all four wheels the fronts stuck out kinda far if my memory serves me right. back then in 1978 they did not have Dream Beams.
235/60/15 FRONT AND 275/60/15 REAR here too .
being lowered I think this will be a good size for you
with truck on the ground measure center of wheel to wheel well lip then take that number and multiply by two . this will give you an idea of how much gap you will have with different tires size (diameter )
The following users liked this post:
351Cleveland C4 that,s good to know. to bad my truck has so much patina on it . you can,t even read the number on the rear axle tag. its there but that,s about it. i will have to use the method of counting turns of the diff. verses the wheel . maybe i will get real lucky. my truck is a 240/tott. i am going to change it to a 302/c4.
