Champion radiator experience
Old Aug 5, 2017 | 05:03 PM
F151's Avatar
F151
What's up guys and gals? I took the plunge without really researching Champion radiators. If you are using one or have used one...what's your assessment? How long did you have it before any issues, if any? Thanks, I ordered the all aluminum type for my 51 Ford F1.
Old Aug 5, 2017 | 05:04 PM
F151's Avatar
F151
Forgot to mention...
I haven't installed it so I still have time to return it for a refund!!!
Old Aug 5, 2017 | 07:27 PM
drptop70ss's Avatar
drptop70ss
I have 3 installed and more on the shelf, no issues, highest miles I have run one is 15000+ so far.
Old Aug 5, 2017 | 07:29 PM
F151's Avatar
F151
Thanks! Good to know. I feel better about my buy.
Old Aug 5, 2017 | 07:35 PM
JPMallory's Avatar
JPMallory
I had one in my truck for a year. It worked to keep the temperature down. Check the cap to see what pressure it has. The stock radiator has very low (if any) pressure. I don't recall what number my cap was, but it was higher pressure for sure, and I'm fairly certain that's what caused my heater core to leak.
Also, the pressure would build up and it would hum to me.
https://www.ford-trucks.com/forums/1...ing-at-me.html
Old Aug 5, 2017 | 08:21 PM
F151's Avatar
F151
the one I got comes with a 16 pressure max. I have a 4 pound pressure cap on my leaking radiator. Would the old cap work better or make it last longer?
Old Aug 5, 2017 | 09:05 PM
drptop70ss's Avatar
drptop70ss
Higher the pressure the higher the boiling point of the coolant. If you have a weakness in the cooling system the higher pressure will find it.
Old Aug 5, 2017 | 09:08 PM
raytasch's Avatar
raytasch
Believe Nothing
I seriously doubt if the original 4lb cap will fit the new
Champion.
I ran a Champion in my F4 for a few thousand miles and it worked fine cooling SOB engine. Another member here has it now.
Old Aug 6, 2017 | 05:50 PM
petemcl's Avatar
petemcl
There are differences in the height of the cap from sealing surface to sealing surface. The old caps were shorter which is why JP's may have hummed. I would stick with a new cap with lower PSI.
Old Aug 7, 2017 | 06:18 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I've had a 3-row in my 53 Chevy since 2014. Cools very well. So far, so good.
Old Aug 7, 2017 | 08:41 PM
lilpanther's Avatar
lilpanther
I have 9600 miles on mine in a little under a year and it's been great so far.
Old Aug 8, 2017 | 08:33 PM
mustangmike6996's Avatar
mustangmike6996
Have a Champion designed for a 350 swap in my F1 (with my 4.6 DOHC) and it keeps the truck cool. I am also running an electric Spal 1600 CFM fan.
I have a 24" rad in my 1969 Mustang. It keeps the car pretty cool but I need to do some work to make my fan turn on sooner.
All in all, for the price, these radiators are great for the price.
Old Aug 18, 2017 | 10:59 AM
F151's Avatar
F151
online it said I would get a 16psi cap but they sent a 9psi cap, would the 9psi cap cause any problems? Should I look for something with less than 9? Thanks
Old Aug 18, 2017 | 11:51 AM
Tedster9's Avatar
Tedster9
The new radiator can stand 16 PSI, the question is whether it will cause problems with the old school heater core or maybe head gaskets.
Old Aug 18, 2017 | 12:37 PM
petemcl's Avatar
petemcl
IMO That's too high. You also need to check the flange to flange measurement? Lots of variation. See this link:
http://www.tridon.com.au/databank/do...iator-Caps.pdf
tgbriggs16
Mar 17, 2019 01:02 PM
mod22
May 10, 2018 04:22 PM
F1 coyote
37
Jun 7, 2017 06:18 PM
reed1951
Ford Truck Parts for Sale
Oct 25, 2015 07:48 AM
BigMikeV
Jan 25, 2015 07:40 PM
