USB PORT power
Old Aug 5, 2017 | 10:00 AM
2017-350's Avatar
2017-350
Thumbs down USB PORT power
Has anyone tried to tap into any of the USB ports to have constant power even when the truck is off? It is frustrating to me to have this truck with every optoin including the ones that i didn't want, but cannot charge my phone if my truck is turned off.
Old Aug 5, 2017 | 10:10 AM
rwilimo's Avatar
rwilimo
I believe this can be changed with Forscan
Old Aug 5, 2017 | 10:48 AM
crewzer's Avatar
crewzer
Lightbulb
I plugged a dual-port high-current USB adapter into the power point inside our truck's center console (front, right, bottom). I believe it remains powered for 75 minutes after the truck's ignition is turned off. The 75 minute time may also apply to the other power points; don't know about the USB ports.
HTH,
Jim / crewzer
Old Aug 5, 2017 | 01:34 PM
2017-350's Avatar
2017-350
HTH,
Jim / crewzer
I've tried that...i can"t get power to anything once i turn the truck off and open a door. It sucks lol
Old Aug 5, 2017 | 01:51 PM
Tricon's Avatar
Tricon
Just change the time out in Forscan.
Old Aug 5, 2017 | 02:06 PM
crewzer's Avatar
crewzer
Lightbulb
Hmmm... I'm running a 75 minute confirmation test in our truck right now. So far, so good. More in an hour or so...
Regards,
Jim / crewzer
Old Aug 5, 2017 | 02:10 PM
shortride's Avatar
shortride
HTH,
Jim / crewzer
Exactly what I do.
Old Aug 5, 2017 | 03:19 PM
crewzer's Avatar
crewzer
Lightbulb
I just had to run a quick errand and so had to cut the experiment short. However, after ~60 minutes, the center console power point was still on.
HTH,
Jim / crewzer
Old Aug 5, 2017 | 04:11 PM
MEBE's Avatar
MEBE
My center console power point stays hot for at least 75 minutes as well, odd some do not.
Old Aug 5, 2017 | 04:15 PM
crewzer's Avatar
crewzer
Lightbulb
May a bum setting in the (body module?). The dealer should be able to do an update, or FORscan allows for a broad range of settings.
HTH,
Jim / crewzer
Old Aug 5, 2017 | 07:12 PM
2017-350's Avatar
2017-350
I need to find someone in the Galveston, Texas are with a Forscan for rent/hire!
Old Aug 5, 2017 | 07:20 PM
Pwrgeek's Avatar
Pwrgeek
I'm in the area (Manvel). PM me and we can work something out.
Old Aug 5, 2017 | 07:56 PM
2017-350's Avatar
2017-350
Thanks for the reply! I can't PM yet, but if you could shoot me an email i would greatly appreciate it
amcgalveston@aol.com
Old Aug 6, 2017 | 02:54 AM
MagicMtnDan's Avatar
MagicMtnDan
Using FORScan you can change the settings so the power to the rear plugs (USB and 110v) can be on 24/7
Old Aug 6, 2017 | 10:12 AM
rwilimo's Avatar
rwilimo
Ford has a bulletin on early build 2017 models for the timing, they will update the BCM software for free, that should get you what others are reporting if you don't want to go the Forscan route.
